Author Topic: New tyres  (Read 1346 times)
Offline dpen
New tyres
« on: May 08, 2006, 03:30:31 AM »
I noticed a topic in the FAQ regarding the dangers of new tyres.
Here is the procedure I've been using for a long time.
Get a scotch-brite pad (like steel wool) & douse it with "sugar soap" (available from any hardware store)
Scrub the tyre including the sidewall for a few minutes. This removes the preservative coating from the tyre.
Wash with water & let dry.
Repeat the process.
When tyre is dry go over it with some wet & dry (about 240 grade)
You still need to take it reasonably easy for the first few miles but you can corner with confidence.
Offline Bob Wessner
  • "Carbs Suck!"
Re: New tyres
« Reply #1 on: May 08, 2006, 05:01:28 AM »
Hope it's OK, I added your procedure to the FAQ.
Offline dpen
Re: New tyres
« Reply #2 on: May 11, 2006, 05:32:58 AM »
It's the ducks guts, Bob.
I've been using it for many years & have introduced a lot of my drivers to it - they swear by it on new tyres.
Offline jotor
Re: New tyres
« Reply #3 on: June 10, 2006, 06:48:23 AM »
FWIW
I googled around a bit and found that "sugar soap" is probably what is called TSP (tri-sodium phosphate) in my neck o' the woods.  I've been using it for years to prep painted walls for new paint.  It's available at Home Depot, etc.
Just re-tired my "real" bike and I'm going out right now to scrub down the tires under the rule that it can't hurt.
Joe
I'd rather ride a Yamaha than eat worms.
Gallery.....http://www.sohc4.us/forums/index.php?topic=2254.0
Offline Bob Wessner
  • "Carbs Suck!"
Re: New tyres
« Reply #4 on: June 10, 2006, 07:28:51 AM »
Thought about that, but I know you have to be cautious letting it sit on some surfaces, such as glass and tile. I wonder, or wondered, what affect it might have on chrome or alumininum, etc. as in leaving a spot/stain.
