Got the old girl running yesterday. A few issues yet to resolve.
When you apply the throttle it appears gas is running out the float bowl of number two (2) carb. I would think the float would keep gas at a certain level. Might be the accelerator pump seal leaking and filling up the float bowl.
Looks like I'll try to remove the bowl without removing carburetors.
I've done a couple of searches on the noise these things put out. They do make a lot of racket it appears. The clutch did quiet down but the transmission does make some noise.
I'll get the leak fixed then do a carb sync as suggested here.
tt
