Author Topic: discs  (Read 1843 times)
Offline cobra
discs
« on: September 02, 2011, 02:30:18 AM »
Hi i have read in one of the posts on here about a company that will take your discs, remove discs from carrier and replace with drilled discs, but i cant find his name anywhere now, can someone shed some light on who he is, and what sort of price do they charge, thanks
Offline fastbroshi
  • Puppet
Re: discs
« Reply #1 on: September 02, 2011, 02:59:18 AM »
He doesn't remove them from the carriers, but runs a blanching grinder on them to thin them down or get them true.  Formulasuper's the name I believe.  Check the Vendors section.
Just call me Timmaaaaay!!!
Re: discs
« Reply #2 on: September 02, 2011, 03:40:47 AM »
speedracer741 in Portland does excellent work as well.
Offline lordmoonpie
    • Moonpie
Re: discs
« Reply #3 on: September 05, 2011, 06:58:19 AM »
Tha's exactly the job done by Len Cooper at C.A.T. Security Engineering in the UK. He takes your old discs, removes the disc, refurbishes the centre and then bolts in a new disc made of cast iron and zinc plated. The zinc plating cleverly stops corrosion in the areas where the pad doesn't contact so making it less rusty looking after it rains! They make stopping a rather awesome one fingered activity!
 Here's some I had done earlier... ;-)
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline cobra
Re: discs
« Reply #4 on: September 06, 2011, 08:00:59 AM »
yes they look good, had a word with them today, and going to get mine sent off, £500, its a lot of money, but if needs must, will have to cut back on the red wine.
Offline lordmoonpie
    • Moonpie
Re: discs
« Reply #5 on: September 06, 2011, 11:36:30 AM »
They really are worth it Cobra - I've had them do it on three bikes now and raced the first two. The braking is awesome if you slap some EBC HH pads in there too. Len's a really top bloke for Honda engineering. You'll be pleased with the result.
Len bought in the cast iron "bar" for my discs originally - it was 290mm diameter and he slices 4mm slices off to make the discs. I think he said it weighed nearly 50 tons!
1994 Ducati 888 SP5
