Be sure to visit the SOHC/4 Web Site for more information on Honda and the SOHC/4 Motorcycles.
I tried to click on your username, but access was denied.
I have no data on the effectiveness of the Esprit rust remover on heavy varnish in a tank. Usually the varnish is removed first. I would be curious to see if the rust remover can remove the varnish; however, I would consider heating the mixed fluid up to 150 degrees if possible. If there is little results, drain the fluid, use a carb cleaner to remove the varnishthen refill the tank with the fluid you drained out. Also use soft or distilled water for the best results.
From Rustdepot.comWill heating the fluid make any difference?A: Yes, the mixture can be heated up to, but not exceeding 150 degrees F to speed the reaction.
I was looking at esprit in regard to cleaning out my tank a while ago. i made a post about the tank and the abuse it had gone through. I used Evaporust and loved it. I read the mustang article but it did make me leary becuase it seemed to good to be true. If someone has used it please respond here to inform us how well it works.... I have another tank I need to clean in the upcoming weeks.
I was leary due to the complexity of using it. Evaporust is pour and wait. Plus I couldn't find much evidence on the effectiveness of Esprit.
