Author Topic: Update - Esprit Rust Remover CONCENTRATE? $38.50 for 5 Gallons  (Read 22361 times)
Offline Rocker
  • The one, the only!
Re: Update - Esprit Rust Remover CONCENTRATE? $38.50 for 5 Gallons
« Reply #50 on: July 20, 2012, 11:12:42 AM »
I have a CB360 tank that needs cleaning as well. I read through this post and tried carb cleaner. Didn't do much which tells me I have surface rust. Anyone else tried Esprit yet?
~Rocker (aka Adam) | rocker@sohc4.net | SOHC/4 member #4151 | Facebook
Current Bikes:
1975 CB750 K5 pic
1974 CB360T " lil' twin " Rebuild thread
1976 CB550 K2 Cafe Racer build thread
1975 CB550 K1 parts bike Parted out and cut up.
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline phaedrus314
« Reply #51 on: July 20, 2012, 06:02:57 PM »
Haven't tried Esprit but I have used wood bleach (oxalic acid) on one of mine and it worked well.
Offline grcamna2
« Reply #52 on: July 25, 2012, 08:03:10 AM »
Esprit is an Excellent product !
Offline AEngelsrud
    • engelsrud.com
« Reply #53 on: July 25, 2012, 09:09:21 AM »
Just ordered Esprit for my 74 cb550.  I'll post some before and after pics once I get it done.
Thanks.
Aaron
Offline Teatimetim
« Reply #54 on: July 25, 2012, 10:56:14 AM »
I did mine with reverse electrysis, used Oxyclean instead of baking soda, with a battery charger on 2amp.  was very successful, did take 3 days, and I recommend you either spray with wd40 or move on to sealing the gas tank right after you clean the solution out, as the tank will start to flash rust.  My cost was about $4, plus the por 15 kit
Bikes I own:
1974 CB550K
1971 CB450
Offline Rocker
« Reply #55 on: July 29, 2012, 08:54:42 AM »
My results from a 24 hour soak with Evaporust. I used one gallon on a CB360 tank.
Current Bikes:
1975 CB750 K5 pic
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline Bailgang
  • Scott
  • Indiana
« Reply #56 on: July 29, 2012, 09:28:04 AM »
Baking soda? Where did that come from? I used Arm and Hammer "super washing soda" which isn't baking soda and it worked like a charm when I did the electrolysis on my gas tank.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline lrutt
« Reply #57 on: July 29, 2012, 04:20:20 PM »
Good old chemtool carb dip will clean a tank, but also eat paint and rubber so you have to be careful. I had an MG TD with the worst varnish muck in the bottom. I put 5 gallons of carb cleaner in there and rotated the tank to a different side for 6 days. Nasty stuff came out but that tank was CLEAN on the inside.
I have a CT90 tank that's pretty bad, think I'll get some of this esprit and try it. Fortunately varnish free, just chunks of rust. Will give it the nuts and shake first though :)
