Author Topic: Finding an exhaust  (Read 1506 times)
Offline buffaloejon
Finding an exhaust
« on: September 03, 2011, 06:45:51 AM »
So it appears there is a decent selection of exhausts out there for a CB750 K6. What I really want is something QUIET. I know, not usually requested, but whatever. I want a nice mellow sound, and not much bite. If it ends up "loud", I want it to sound like a racer, not like the chopper it sounds like now.
So yea, what exhaust could fit my requirements? I can't find many videos that I like the sound of that list what type exhaust it is, so I figured I'd ask the guy's who would know!
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
76 CB750K
http://photobucket.com/buffaloejon
Re: Finding an exhaust
« Reply #1 on: September 03, 2011, 06:50:05 AM »
Are you rich or comfortably well off ? Can't beat the stock 4-4 HM341's if you want quiet.
Offline buffaloejon
« Reply #2 on: September 03, 2011, 06:59:50 AM »
Mm, actually definitely the opposite end of the spectrum... Starving college student who can't buy his books because I bought a motorcycle...
So yea. Would cycle-x's 4-1 ($229) exhaust be quiet(ish) w/ baffles and a glass pak if they have them?
76 CB750K
Offline MidnightLamp
  • Wrenchy wrenchy wrench!
« Reply #3 on: September 03, 2011, 08:56:02 AM »
Get a set of mac 4-2's and install a set of better mufflers on them. Some work will definitely be needed.
the cycle-x exhausts, the mac's (stock), and kerkers are all louder than stock.
'75 CB750 - Racer
'69 CB350 - Racer
'68 Enfield 350/440(flat top) - Steet
'54 Enfield 350 - Resto
'74 Commando 850 - Restomod
'67 Enfield 750 (TT7) - Resto
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #4 on: September 03, 2011, 10:55:39 AM »
I'm curous- can anything be done to an off the shelf Mac 4 into 1 to make it quieter? I also miss the mellow tone of my old stock 4 into 4.
Offline buffaloejon
« Reply #5 on: September 03, 2011, 11:07:20 AM »
I think what I'm going to do is get the cheap(est) MAC exhaust, the 4-1 black, and put a glass pack. That oughta be decently "quiet" right? At least a little more subdued at idle. Anyone got experience with that?
76 CB750K
Offline mrbreeze
  • Not your average
« Reply #6 on: September 03, 2011, 11:15:21 AM »
I just bought a MAC muffler that looks just like an old Kerker Megaphone. It was so quiet I took the baffle out and put in a Kerker cone without the baffle I mounted this muffler to my Kerker header that I got years ago on E bay for $50. $150 for muffler from Dennis Kirk + $50 for used Kerker header = cheap exhaust that looks and sounds great!!
MEMBER # 257
« Reply #7 on: September 03, 2011, 12:39:44 PM »
Baffled headers are real damn quiet. A single glasspack on a 4-1 (think cherrybomb style) will not do too much. It will remove some of the rasp, but that's about.
A 4-2 is nice in that regard, as the pair of mufflers can be a little less restrictive and you'll get a good sound.
« Last Edit: September 03, 2011, 10:25:28 PM by MidnightLamp »
'75 CB750 - Racer
'69 CB350 - Racer
Offline buffaloejon
« Reply #8 on: September 04, 2011, 08:54:40 AM »
Hmm, duly noted. Has anyone got a video of what the MAC exhaust sounds like?
Cycle-x also has a supersport slip-on that they say is super-quiet, I may look into that.
Has anyone had any experience contacting Cycle-x? I would like to get in touch and see if I could get some advice from them, about a good, inexpensive combination of headers/mufflers, and what they would sound like, since they should know.
76 CB750K
Offline wanackg
« Reply #9 on: September 04, 2011, 09:22:30 AM »
Build your own and install an ungodly amount of baffles  ;D
1981 Honda CB650 Custom
#$%* happens. It's what you do when it hits the fan that matters
When my time comes, I want to be buried face down so that anyone who doesn't like me can kiss my ass. -Red Forman
Offline Danno
« Reply #10 on: September 04, 2011, 09:40:23 AM »
if your head pipes are not shot and on a k6 I doubt it cut them apart at the mufflers so they are as long as possible then loosen them at the heads so they will move
move the pipes around till two of them line up together on each side
I had to swap the two inside piped side to side to get them to line up together
once you have two pairs together on each side tighten the header bolts back down
weld on a car resonator not a glass pack they look like glass packs but have 7 baffles each in them
after the resonator is welded to the pair of pipes you take a 2 inch washer and weld it in the end of the resonator
then you take a 7/8" drill bit  or step drill bit and cut the hole in the washer bigger
this will result in a quiet deep rumble sound that is not restrictive
if you need more restriction in the exhaust so you don't have to rejet then leave the whole in the washer smaller
paint the entire header system and resonators black using wood stove paint you can find at TSC or farm and fleet
« Last Edit: September 04, 2011, 09:42:04 AM by Danno »
Offline N30R3L0AD3D
  • Gearhead
« Reply #11 on: September 04, 2011, 09:41:56 AM »
I bought a MAC 4 into 1 black header from dennis kirk. It's a cheap pipe, but it works. You can see in the video, already the paint on the header flaking off and some rust from riding in 2 rain storms in 2 years of owning it.
Here's a video to compare sound (quality kinda sucks).
Mind you I've done a lot of work to my bike too. It's not stock.
MVI_2263.AVI
I also should mention, it allows you to change the oil filter and let's you use your rear foot peg for a passenger.
« Last Edit: September 04, 2011, 09:46:24 AM by N30R3L0AD3D »
1974 CB750K Honda
Offline buffaloejon
« Reply #12 on: September 04, 2011, 10:24:48 AM »
MVI_2263.AVI
I do like that. I think with the quiet supersport header on cycle-x's page, that could be promising. I like the supersport sound, but I also like quiet. I don't want my classic motorcycle to sound like a mosquito. Or on the other end of the spectrum, which it is now.
But as for Danno's suggestion, I'm selling the exhaust on it now, and its a full exhaust, not header and mufflers.
76 CB750K
