Author Topic: Tach issues.  (Read 2110 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Tach issues.
« on: September 03, 2011, 05:59:57 PM »
Tach stopped spinning.
Took of the cable and a little metal tab fell out and the tach spinner from the engine is almost flush. what is this called and how do I change it?
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Tach issues.
« Reply #1 on: September 03, 2011, 09:10:10 PM »
How easy is this to pull out and replace? Better going tachless for a while?
Gus, Austin, MN.
Offline the technological J
  • deliciouso!
Re: Tach issues.
« Reply #2 on: September 03, 2011, 10:26:52 PM »
not too bad i would say... is the tach cable shot? or is it definatly the actual tach gear.... you would have to buy also a new valve cover gasket... dunno about the availability of the gear... but you pull the valve cover, flip it over and it should be a fairly easy replacement
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline wrenchmuch
Re: Tach issues.
« Reply #3 on: September 04, 2011, 06:05:56 AM »
The end of the gear is broken . You should see two tabs at the end of it with a slot in the middle that the tab on the end of the tach cable fits into. The gear comes out easy once the cover is off the top of the engine . If you do replace the gear check the cable and tach for any kind of binding before you start it again .
CB750K1
CB750K4
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=mgb11ojk5lb1rlf63bghst2sb6&/topic,60973.0.html
Re: Tach issues.
« Reply #4 on: September 04, 2011, 06:21:48 AM »
mine are also broken..cant find a new. think you can pull it aut..not" ness "to take the cover off
i hate all this v-w.... vords
Offline johnrdupree
Re: Tach issues.
« Reply #5 on: September 04, 2011, 11:17:29 AM »
If you can get a grip on what's left of the drive gear shaft you should be able to just pull it out.  The only thing holding it in place right now is the o-ring.  Here's a picture of mine:
It looks like the outer part of the unit and the tab on the gear shaft are both broken.  According to Motogrid, the housing is still available from Honda but the gear shaft isn't.  Looks like you'll have to source a used one.
Good Luck,
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Tach issues.
« Reply #6 on: September 04, 2011, 12:33:32 PM »
Ive got another one. Your saying I can just yank on the broken piece (attached to the top end) and it should come out?
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Tach issues.
« Reply #7 on: September 04, 2011, 01:06:00 PM »
Pulled right out! Thx
Gus, Austin, MN.
