SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Fork Oil Capacity of 1977 CB750F2
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Fork Oil Capacity of 1977 CB750F2 (Read 6117 times)
Deacon Thunder
Full Member
on:
September 04, 2011, 06:13:11 am »
I read about a hundred post after doing a search....no luck find the fork oil capacity for my 1977 CB750F2. Anybody have that information they could share? The forks are rebuilt with new seals and dust caps..even new paint on the lower legs. If that makes any difference.
DT
Logged
bollingball
Guest
Re: Fork Oil Capacity of 1977 CB750F2
Reply #1 on:
September 04, 2011, 06:52:49 am »
Try the service manual chapter 11. I think it 7-7.3 oz it will depend on how you want it to handle as to what weight to use. Look at the supplement for 77 they may have made a change if so it will be there.
Here is the manual it is the one that says 69-78 huge file.
Last Edit: September 04, 2011, 07:02:34 am by bollingball
Logged
madmtnmotors
When did I get to be a
Really Old Timer ...
Sunny Central Florida
Reply #2 on:
September 04, 2011, 07:01:52 am »
The downloadable manual from this site can be found here:
http://www.sohc4.net/?page_id=133
The specification page from the F1/F2/F3 supplement is attached.
Logged
TAMTF...
Wilbur
Projects:
"Evolution":
http://forums.sohc4.net/index.php?topic=100352.0
"P.O. Debacle":
http://forums.sohc4.net/index.php/topic,126692.msg1441661.html#msg1441661
F2/F3 O-rings:
http://forums.sohc4.net/index.php?topic=113672.msg1300721#msg1300721
Cam Tower Studs:
https://www.mcmaster.com/#93210a017/=t19sgp
Clean up that nasty harness:
http://forums.sohc4.net/index.php?topic=137351.msg1549191#msg1549191
http://oldmanhonda.com/MC/wiring750K1.html
Charging system diagnosis:
http://forums.sohc4.net/index.php?topic=1012.msg8345#msg8345
Get the manuals:
http://manuals.sohc4.net/cb750k/
The Dragon:
http://forums.sohc4.net/index.php?topic=45183.msg1571675#msg1571675
Headlight Switch:
http://forums.sohc4.net/index.php?topic=113986.msg1283236#msg1283236
Branden's leak free top end thread:
http://forums.sohc4.net/index.php?topic=107040.0
Engine Lifting Made Easy:
http://forums.sohc4.net/index.php/topic,58210.msg1684742.html#msg1684742
Static and Dynamic Timing:
http://www.hondachopper.com/garage/carb_info/timing/timing1.html
Airbox Gasket Replacement:
http://forums.sohc4.net/index.php/topic,114485.msg1290000.html#msg1290000
"Café" :
http://forums.sohc4.net/index.php/topic,84697.msg953814.html#msg953814
PD Carb Choke Linkage:
http://forums.sohc4.net/index.php/topic,100352.msg1669248.html#msg1669248
Follow up on your damn posts:
http://forums.sohc4.net/index.php/topic,144305.msg1791605.html#msg1791605
Taiwanese Cam Chain Tensioners:
http://forums.sohc4.net/index.php/topic,155043.msg1774841.html#msg1774841
Gumtwo Seat Cover:
http://forums.sohc4.net/index.php/topic,164440.msg1897366.html#msg1897366
Primary Drive:
http://forums.sohc4.net/index.php/topic,166063.msg1919278.html#msg1919278
Tank Latch:
http://forums.sohc4.net/index.php/topic,165975.msg1919495.html#msg1919495
Shorten your forks:
http://vintage-and-classic-honda-s.456789.n3.nabble.com/How-to-shorten-forks-td4042465.html
DO NOT CUT THE SPRINGS!
Clutch How To:
http://vintage-and-classic-honda-s.456789.n3.nabble.com/How-to-change-and-adjust-a-clutch-SOHC-td4040391.html
Late model K7/K8/F2/F3 front sprocket cover removal:
http://forums.sohc4.net/index.php/topic,178428.msg2072279.html#msg2072279
630 to 530 conversion:
http://forums.sohc4.net/index.php/topic,180710.msg2094423.html#msg2094423
Sent from my Tandy TRS-80!
bollingball
Guest
Reply #3 on:
September 04, 2011, 07:04:11 am »
Mad I knew I forgot something
Logged
madmtnmotors
Reply #4 on:
September 04, 2011, 07:11:13 am »
bollingball,
You got your post up while I was still chasing links for mine!
Logged
TAMTF...
Wilbur
Projects:
"Evolution":
"P.O. Debacle":
F2/F3 O-rings:
Cam Tower Studs:
Get the manuals:
The Dragon:
Headlight Switch:
"Café" :
Gumtwo Seat Cover:
Primary Drive:
Tank Latch:
Shorten your forks:
Clutch How To:
Deacon Thunder
Full Member
Reply #5 on:
September 04, 2011, 02:43:04 pm »
Thanks for your help gentlemen. I used the F specific information and installed 155cc approx 5.2oz of oil in each fork. Thanks again for pointing me in the right direction.
Note of interest: I purchased a set of new dust boots for the forks. The boots are too loose to stay in place as the fork moves. I saved the old boots in case the silicone adhesive I glue them with doesn't work out.
Logged
madmtnmotors
Reply #6 on:
September 04, 2011, 04:02:53 pm »
Double check that you have the correct boots. The 77'-78' 750F model dust boots actually fit down inside the top of the fork, while the 76' 750F and 77'-78' 750K model (and possibly others) dust boots fit OVER the top of the fork lower.
Logged
TAMTF...
Wilbur
Projects:
"Evolution":
"P.O. Debacle":
F2/F3 O-rings:
Cam Tower Studs:
Get the manuals:
The Dragon:
Headlight Switch:
"Café" :
Gumtwo Seat Cover:
Primary Drive:
Tank Latch:
Shorten your forks:
Clutch How To:
Deacon Thunder
Full Member
Reply #7 on:
September 04, 2011, 05:02:41 pm »
Yeah I got the right ones. They just don't fit well and the rubber is too soft.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
