Author Topic: A few 550 into a 500 Q's...  (Read 1915 times)
Offline Scott S
« on: September 05, 2011, 08:14:21 AM »
 I picked up a complete '76 550 engine last weekend. It has the 087A carbs and a spare wiring harness.
 Supposedly, it came from a running bike.
 I plan to clean the carbs and detail/tune up the engine and drop it into my '71 CB500. Pretty straightforward, right?
 A few questions, though:
1) The 550 engine was missing all the advance stuff; points plate, retaining bolt, mechanism, etc. I found all the parts and I plan on running a Pamco anyway, but the spare advance I have is from a CB500. It has "323" on it and "AD125-02".
  Any problem with running that in a 550 engine?
2) I did a search on the 087A carbs and see a few people having issues with them. I know that externally they're the same as my 627B carbs and all the changes were interanl: needle profile, etc. I'm guessing that Honda was going towards leaner running as part of the emissions process.
  I have a rack of 627B carbs that I could use to swap out jets, needles, etc. Any benefit to that?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Re: A few 550 into a 500 Q's...
« Reply #1 on: September 05, 2011, 08:20:03 AM »
All the advance/points stuff is the same,
Main difference in carbs is jet sizes--its the later 77/78 carbs that are a real sod
You will also need the RH rear engine mount plate as it has the clutch cable stop on it.
Apart from that its good to go
Offline Scott S
« Reply #2 on: September 05, 2011, 08:25:06 AM »
 Glad you told me that......back to the junkyard....
'71 CB500 K0
'81 Yamaha XS650
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #3 on: September 05, 2011, 08:43:19 AM »
Offline Scott S
« Reply #4 on: September 05, 2011, 10:28:03 AM »
 This is what I needed, right?
 I guess that means I'll need the later clutch cable, too? My CB500 has the early style clutch cable that goes into the LH sprocket cover.
 Greggo, off to read that thread right now!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #5 on: September 05, 2011, 10:41:06 AM »
 Oh yeah...I searched for quite a while the night I brough the engine home, but where can I find a serial # look-up?
 I'm 99% sure it's a '76, but where on this site is a cross reference?
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #6 on: September 05, 2011, 12:14:25 PM »
 And from another thread: "the 500 has a 34 rear sprocket,the 550 has 37,itll have a tall gearing if you dont change to a 37,the different transmissions have different gearing internaly".
 I JUST bought a new 100 link chain for my CB500. Haven't even taken it out of the box yet. I'm guessing it will be too short for the 37 tooth 550 sprocket?
'71 CB500 K0
'81 Yamaha XS650
bollingball
« Reply #7 on: September 05, 2011, 12:15:04 PM »
Scot there is another list I was looking for but can not find it. Maybe this will help.
http://www.sohc4.net/?page_id=2765
Offline Scott S
« Reply #8 on: September 05, 2011, 12:55:04 PM »
 Yep, it's a '76 K model.
  And it appears that the 17/34 and 17/37 sprocket combos both use a 530/100 chain, which is good since I have a brand new one on the work bench.
'71 CB500 K0
'81 Yamaha XS650
« Reply #9 on: September 05, 2011, 10:34:21 PM »
According to all the aftermarket suppliers the 500 and 550 clutch cable are the same.
That is the correct bracket
Also DO NOT PAINT the bracket where the big engine bolt goes through as this is where the battery ground cable goes and it need to make good contact with the bracket and the bracket good contact with the engine case
