Author Topic: Speed Holes!  (Read 1755 times)
Offline srbakker
  • Spam & Eggs
Speed Holes!
« on: September 05, 2011, 09:55:45 PM »
For those if you drilling your rotors/rear brake hubs/frames (no, not really) full of speed holes, are you freehanding it or using a template or just doing it on a drill press?
Scott
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
Re: Speed Holes!
« Reply #1 on: September 06, 2011, 06:08:08 AM »
At one time on a thread here a guy was posting up some templates that people could use.Maybe it can still be dug up.
KingCustomCycles.com
Re: Speed Holes!
« Reply #2 on: September 06, 2011, 06:13:19 AM »
template. center punch, drill press.
Offline wrenchmuch
Re: Speed Holes!
« Reply #3 on: September 06, 2011, 06:19:25 AM »
CB750K1
CB750K4
Re: Speed Holes!
« Reply #4 on: September 06, 2011, 06:26:47 AM »
And don't skimp on the drill bits,put the good ones in your lunchbox at work  ;D :o
Offline srbakker
  • Spam & Eggs
Re: Speed Holes!
« Reply #5 on: September 06, 2011, 11:18:53 AM »
Haha - good advice!  Of course - the supplies I steal from work are of a different sort... ;)
Thanks for advice and the template links everyone!
1975 CB750 K5
2007 Triumph Tiger
Offline StreetSpirit
Re: Speed Holes!
« Reply #6 on: September 06, 2011, 12:25:39 PM »
I'm planning to drill the rotor on my cb550 rotor at some point, but I'm also wondering if anybody has turned down these rotors for decreased thickness?  I'm thinking about running the original wheel with a modern fork/caliper.  The standard disc for the nice 4 pot caliper I have is like 3.5 mm, so I would need to lose something like 1mm off the cb's rotor.
Bad idea?  Any options?  Guess I could always shave the caliper instead.
Offline Steve F
Re: Speed Holes!
« Reply #7 on: September 06, 2011, 06:30:42 PM »
There is a minimum thickness for the rotor and that number is usually cast in the rotor hub somewhere.  I wouldn't recommend going less than that number.
Offline fastbroshi
  • Puppet
Re: Speed Holes!
« Reply #8 on: September 06, 2011, 11:24:21 PM »
+1, I think the min. thickness on the 550 rotors is like 5 or 6mm
Just call me Timmaaaaay!!!
Offline Danno
Re: Speed Holes!
« Reply #9 on: September 06, 2011, 11:50:05 PM »
the rotor will fold up if you undersize it from spec that is why the spec is there if you want more brake power drill it and add a second rotor caliper to the other side it will cost less than the conversion instructions are here on the forum
Offline johnny
Re: Speed Holes!
« Reply #10 on: September 07, 2011, 03:30:17 AM »
Member Godffery sells thinned and drilled rotors for sohc4's.
I've got one on my 350.
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/album185/Brake+Rotors+_+Thinned+and+Drilled/
1976 CB550K
1974 CB350F http://forums.sohc4.net/index.php?topic=81781.0
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
