SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Caliper question
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Caliper question (Read 883 times)
Graydude
Full Member
Caliper question
on:
September 06, 2011, 08:41:31 AM »
Can anyone show me a picture or tell me where the small clips go on the caliper for a 78 CB750F? None of the fiches I"ve seen show these clips. I'm talking about the the two smaller ones. I think one goes on each caliper but I was asleep when I took them apart a few months ago. Now I can't figure out where they go. I saw one reference to these that called them retaining clips but I don't know. Can anyone help?
Thanks, Graydude/Todd
Logged
Check out the Rust Bucket build
http://forums.sohc4.net/index.php?topic=89770.msg1005198#msg1005198
OldSchool_IsCool
Really feeling like an
Old Timer
WARNING: Objects in mirror appear to be LOSING!
Caliper question
Reply #1 on:
September 06, 2011, 10:57:48 AM »
Those look like parts on my Goldwing caliper. Are you sure your caliper is original?
Logged
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Graydude
Full Member
Re: Caliper question
Reply #2 on:
September 06, 2011, 12:33:37 PM »
Not sure if they are the orginal calipers. No history from the POs. Do you have those on your GW and if so, maybe I can find that application.
Logged
OldSchool_IsCool
Old Timer
Caliper question
Reply #3 on:
September 06, 2011, 12:46:10 PM »
Does the caliper have single or double pistons?
Logged
Sure.
Is it hard?
KingCustomCycles.com
Guest
Reply #4 on:
September 06, 2011, 01:01:38 PM »
If memory serves, the two little ones go on the ends and the bigger one goes underneath the pads against the metal backing plate.
Logged
OldSchool_IsCool
Old Timer
Caliper question
Reply #5 on:
September 06, 2011, 01:34:01 PM »
Sounds about right, King, but there should only be one small clip per caliper.
For a blow-up, look at the parts fiche of a '81 GL1100 for single piston or '82 GL1100 for dual piston.
Logged
Sure.
Is it hard?
Graydude
Full Member
Reply #6 on:
September 06, 2011, 01:39:59 PM »
Thanks guys. It's a single piston and I know the H looking clip goes up against the caliper body. I seem to remember one clip per caliper but you can see the little U channel at the top of each clip is a little different. I have two with the smaller U cut out and one as shown with the bigger cut out. I will check out the GW drawing. Thanks again!
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
Caliper question
