Say YES to Crack..!!
The benefits of never washing a 750!!
The above 2 could have been alternate titles..
Last fall.. or the one before I had trouble with the 750 running on 3 cylinders, took me a long time to sort out till I realized, I had lost a synch screw and was sucking air. I fixed it, it ran fine..
Last night I was setting my valves, started getting noisy on the weekend. I may not have set them in the last 2 yrs = 500 + rides!
It was hot and I was cooling the motor with water to be able to set the valves. #1 was at 8 and 6 thou! I was sitting beside the bike on a bucket putting water on it and spied something in the crack between the clutch cover and the main case at the front of clutch cover.. and I see the screw and washer.
I am looking at it and I soon realize it is a sync screw..!!!
the soft washer looked like a cowboy hat brim and was probably holding it in place!. Now the very strange part, I had the cutch cover off this spring, so I really think it could not have stayed there, while removing the clutch cover... plus I would have seen it.
I was very surprised to see that show up 11 months and at least 250 rides later..
Ever refind your lost stuff?
