Author Topic: Tool for valve guide seals  (Read 605 times)
Offline lucky
« on: September 06, 2011, 04:04:41 PM »
Tool for valve guide seals without head removal.
Not a fancy tool but it works well.
I just put in the rocker arm shaft and use it as a hinge point.
If you make a tool, make sure it will not scratch the rocker shaft.
Offline lucky
Re: Tool for valve guide seals
« Reply #1 on: September 10, 2011, 07:14:26 PM »
I want to withdraw my suggestion for my tool because although it worked for removing the keepers, I had a lot of trouble trying to install the keepers after changing the valve guide seal.
Still have not solved the problem.
Chrysler car company uses one very similar too.
I will modify mine to see if I can make it work better.
Needs a longer handle, and needs to push the spring down about 1/8 inch more.
I will report back.
« Last Edit: September 11, 2011, 01:31:12 AM by lucky »
