Author Topic: 1972 cb750 bobber build  (Read 6577 times)
Offline fitdirtjmpr4130
« on: September 06, 2011, 09:01:01 PM »
i picked up a 1972 cb750 from my boss for FREE!
i always liked the bobber style so i started stripping it down and ordered a hard tail from TC BROS CHOPPERS.
Re: 1972 cb750 bobber build
« Reply #1 on: September 06, 2011, 09:04:29 PM »
i used a harley tank from dennis kirk. took a old set of 7/8 mountain bike bars and flipped them. the rear fender is off a yamaha maxim. cut the stock pipes for now.
i also ordered a set of new tires. bridgestone accolade 100/90-19 front and a 130/80-18 rear
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« Reply #2 on: September 07, 2011, 02:00:05 PM »
looks like a  nice project... keep us posted.
 btw, you planning on adding baffles to those pipes or going with another set altogether?
« Reply #3 on: September 09, 2011, 01:28:47 PM »
im planning on running the pipes wide open for now and re jetting the carbs. if its too obnoxious then i will baffle them or make something else.
Offline hapakev
  • Your Standard
« Reply #4 on: September 09, 2011, 05:48:11 PM »
You're off to a good start man.  Looking forward to the progress.
Smoking Jack
1978 CB750F(ish)
Offline Free Booter
  • My Build: CB750k5
  • Meh.
« Reply #5 on: September 09, 2011, 10:12:12 PM »
I've been looking at that TC Bros weld on...nice.
« Reply #6 on: September 10, 2011, 04:13:21 PM »
the only thing with the tc bros hardtail is you have to drill through the frame for the rear brake pivot, they dont tell you that. also the way they tell you to space the rear wheel is wrong, it puts it way too far to the brake side and the chain will not line up. a little common sense and you will be fine. other then those two little things, i absolutely love the hardtail they sell!
Offline lucky
« Reply #7 on: September 12, 2011, 01:45:19 AM »
I see other problems with that hard tail. Like all the cut open tubes that can get filled up with water and start to rust inside.
All of the cut off tubing needs to be closed up to prevent corrosion. No oxygen- no corrosion.
I think the stock frame lowered with shorty 11.4 inch shocks is far better all the way around.
Next would be a stock frame with short struts.
« Reply #8 on: September 13, 2011, 01:41:58 PM »
ya, im not leaving the frame open... never said it was done.
Offline 92sc300tt
« Reply #9 on: January 04, 2012, 05:32:42 PM »
Can you post a picture of your rear brake setup at the pedal and the rear drum?
Offline valt
« Reply #10 on: January 05, 2012, 08:06:14 PM »
Hey I have a TC bros weld on as well. If you have any questions regarding it let me know and I can grab detailed pictures on anything you have questions about. I have been pretty pleased with mine so far. I also have a build thread where you can see my bike in various stages.
Offline lucky
« Reply #11 on: August 23, 2012, 01:09:20 PM »
You are right I was jumping the gun. The tank looks like a very good choice.
