Author Topic: 550K fork seal replacement question  (Read 5797 times)
Offline johnrdupree
Re: 550K fork seal replacement question
« Reply #25 on: September 10, 2011, 04:58:05 AM »
RAWNOG, read this: http://forums.sohc4.net/index.php?topic=84133.msg948284#msg948284
It's a "special tool" I made when taking apart my forks.  The damper rod had a pin in the top and this tool engages that pin to keep the rod from spinning.  Beats the broom stick method hands down.  Since you already have one apart you can use that damper rod to make sure your tool will grab the pin.
Good Luck,
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline cameron
« Reply #26 on: September 10, 2011, 09:31:05 AM »
alright, I went bought a vice (needed anyway) and clamped that sob in, which got the left one out but the right one keeps spinning as you said. I cursed and kept spinning and Im hoping the PO didnt strip it out somehow.
Still stuck? Tell me you finally got it?
1976 CB550F
Offline RAWNOG
  • Pretty pretty pretty pretty... Pretty good.
« Reply #27 on: September 10, 2011, 09:49:49 AM »
Got it ;D
1975 CB550k
Offline cameron
« Reply #28 on: September 10, 2011, 04:50:57 PM »
HA HA!
What was the trick?
1976 CB550F
Offline RAWNOG
« Reply #29 on: September 10, 2011, 06:48:58 PM »
Viced it, hit it with a ratchet and an allen bit. Now on to the new problem... my front brake is not responding at all when pulled in.
1975 CB550k
Offline cameron
« Reply #30 on: September 10, 2011, 08:08:11 PM »
spring adjusted correctly?
1976 CB550F
Offline RAWNOG
« Reply #31 on: September 10, 2011, 09:12:38 PM »
not sure, but i just went in there and tightened up the flathead that holds the caliper in place. Im pretty sure its the adjuster youre talking about, with the spring on the other side.
1975 CB550k
