Author Topic: Holy bearings, Batman!  (Read 2493 times)
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« on: May 08, 2006, 07:41:22 PM »
I swapped out the front end on my 175 today.  I guess I should have studied the diagrams a bit closer.  Seems the bearings are UN-housed, as evidenced by the 'raindrops' of balls falling all over the place. It took a while, but I finally found all of them.  I guess I just assumed it was a housed bearing.  It should be fun trying to re-assemble everything without them continuously falling out. Another day, another lesson learned.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline kghost
Re: Holy bearings, Batman!
« Reply #1 on: May 08, 2006, 07:56:10 PM »
When reassembling...........
If you grease the bearings as you should the grease will hold the balls in place while you're inserting .
Stranger in a strange land
Offline csendker
« Reply #2 on: May 08, 2006, 08:22:36 PM »
That's what I was figuring.  I've cleaned up all of the raceways & the bearings, but I have to wait until tomorrow when I can pick up some grease for the reinstall.
Offline byidesign
« Reply #3 on: May 09, 2006, 11:33:39 AM »
The first time that happened, I said a lot of
    bad words, and had to go back to the shop to
         replace the one's I couldn't find...
      you were lucky...........
                Bruce
82CB650SC,80CM400
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #4 on: May 09, 2006, 09:29:32 PM »
Why not use this opportunity to replace the old ball bearings with a sealed tapered system?
It makes a lot of difference to the handling and steering of the bike.
Offline kghost
« Reply #5 on: May 09, 2006, 11:00:05 PM »
True Enough.
I only use those old balls for assembly during mock up
When all is powdercoated or painted tapered it is
« Reply #6 on: May 10, 2006, 01:39:39 AM »
Can you buy a tapered roller bearing kit for a 175? Probably not, but if you can find one, get one for sure. Before you re-install those 30+ year old steering head ball bearings, check them and the races for damage, I'd be surprised if they're any good to be honest.
The balls should be available from most engineering supply stores, but the races might be a little thin on the ground by now, so best of luck! Cheers, Terry. ;D
