Author Topic: bolt strength question...  (Read 1589 times)
amattel
« on: May 08, 2006, 10:01:49 PM »
I was out bolt hunting today at the hardware store.
What are the practical differences between a bolt stamped 8.8 and one stamped 10.9?
thanks,
Adam
amattel
Re: bolt strength question...
« Reply #1 on: May 08, 2006, 11:17:47 PM »
This is an m8 x 75mm x 1.25 pitch
these numbers (8.8 and 10.9) Refer to the metal the bolt is made from....  I am just not clear about what it means in a practical sense....
Any metals experts out there who understand the difference?
thanks,
Adam
Offline scunny
  • don't call me expert
« Reply #2 on: May 08, 2006, 11:27:51 PM »
steel grade 8.8---Made from medium carbon steel and zinc plated. Best for general hardware use where high strength is not required. Standard metric thread pitches
steel grade 10.9---Made from alloy steel quenched, tempered, and zinc plated (usually yellow). Best for automotive use and other areas where high strength is needed.
hope this helps
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Noel
« Reply #3 on: May 08, 2006, 11:30:20 PM »
8.8 is medium carbon steel, quenched and tempered. Yield strength should be 92,000 PSI and tensile strength should be 120,000 PSI.
10.9 is alloy steel, quenched and tempered. Yield strength should be 130,000 PSI and tensile strength should be 150,000 PSI.
< edit > Oops, scunny beat me to it. :)
'73 CB500
Offline Clyde
« Reply #4 on: May 09, 2006, 12:24:35 AM »
This a brief explanation (which supports Noel's posting).
The numbering system is an ISO standard and slightly different to the American grading system
The numbers are used to calculate the tensile and yield strength of a bolt.
They work in mpa instead of psi, as the numbers use metric units.
The 8 refers to an ultimate Tensile strength of 800mpa which is roughly equivalent to 120,000psi. The second 8 is used to give the yield stress and is calculated by multiplying the two numbers together (8X8) and then multplying by 10 to give 640mpa or 92000psi
Check the following site out as it gives a better explanation
http://www.obex.co.za/data4.html
A even better site which gives both the ISO and American gradings is
http://www.boltdepot.com/fastener-information/Bolt-Grade-Chart.aspx
Regds
Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
78CB750F1
« Reply #5 on: May 09, 2006, 12:40:00 AM »
If you can afford the difference in price, choose the 10.9, especially for nuts and bolts that are under load.  My father used to prepare race cars - the first thing he did was replace all the hardware he could with 10.9.
Offline mrbreeze
  • Not your average
« Reply #6 on: May 09, 2006, 12:45:57 AM »
Great post !! I printed this and highlighted the sites that Clyde listed.Should go to FAQ .I don't know what catagory it should be in though.
MEMBER # 257
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #7 on: May 09, 2006, 09:38:23 AM »
General FAQ !
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
amattel
« Reply #8 on: May 09, 2006, 10:59:50 AM »
Thank you so much!
One more question.
The other choice I had when choosing a bolt was whether or not it was flanged.
I believe this means the washer-shaped section which extends beyond the edge of the hex head.  It seems like this would add more stability and strength, but what is the official benefit/use fo this?
thanks,
Adam
Offline dusterdude
« Reply #9 on: May 09, 2006, 12:28:47 PM »
essentially.the flanged head replaces using a washer separately.it also spreads the load better against what you are tightening up.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
