Author Topic: how do you remove exhaust studs?  (Read 3755 times)
Offline xsmooth69x
« on: September 09, 2011, 07:50:34 PM »
like the title says .... how do you remove the exhaust studs?
1975 CB550 (FINISHED?!?!?)
Re: how do you remove exhaust studs?
« Reply #1 on: September 09, 2011, 08:22:35 PM »
On the 72 CB750? Should be flat top Allen head screws? On which I would use a hammer impact driver.
If you've got studs they may have been put it by the PO. I'd use a proper stud remover.
http://www.craftsman.com/shc/s/search_10155_12602?vName=Hand+Tools&keyword=stud+remover&sLevel=0&sid=ISx20110429x00001&psid=64x5019
They are cheaper at harbor Freight.
Offline splitt
« Reply #2 on: September 09, 2011, 08:23:31 PM »
I double-nutted mine, then used a punch and hammer. I put the punch on the end of the stud then smacked the punch with a hammer in quick concessions. (like a woodpecker) That should break the oxidation loose so that you can put a wrench on the double-nut to turn it loose. If it still won't come loose, remember penetrating oil is your friend.
Offline xsmooth69x
« Reply #3 on: September 10, 2011, 03:35:59 AM »
this is for my honda cb550
double nut!!!!! i googled the technique and i cant believe i didnt think about it duh
Offline bender01
« Reply #4 on: September 10, 2011, 05:42:09 AM »
I would heat the outside area also with a propane torch. Make it even easier.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline Freaky1
« Reply #5 on: September 10, 2011, 06:09:48 AM »
I asked the guys at the head shop to remove the ones I couldn't get out when I dropped it off.  ;) ;) ;)
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline jdubb1977
« Reply #6 on: September 13, 2011, 04:55:08 PM »
yep, heat & an impact driver.  you may mess a few up getting them out, but you can always replace them w/ new, non rusty versions :)
pat english
« Reply #7 on: September 13, 2011, 05:00:57 PM »
The threds on my 750 studs were already jacked.I planned on using screws anyways.so I just used vise grips..didn't need to heat anything up.
