Author Topic: 1977 CB550K Cafe Racer Build  (Read 6243 times)
Offline illrational
« on: September 10, 2011, 08:03:49 AM »
OK ill give all the details good and bad....first off i bought the bike for 1200 and as you see later i got #$%*ted on...i test rode it with the choke on and aethestically it looked really good plus i was seeing bikes going or atleast being offered for 2 3 even 4 thousand. Well the bike would run without the choke on so i deceided to take carb apart and clean it but with carb apart i decided i would take a look at top end because when i took my spark plugs out they looked bad and when i looked in the spark plug port it was crispy. What i found wasnt good as you can see by the pictures....almost forgot as im cleaning up swing arm it looks like part of it was as welded on after a possibly accident...things just keep getting better
« Last Edit: September 17, 2011, 07:26:50 PM by illrational »
Offline illrational
Re: 1977 CB550K Cafe Racer Build
« Reply #1 on: September 10, 2011, 08:32:38 AM »
How much trouble do you think im in?
« Last Edit: September 10, 2011, 08:37:01 AM by illrational »
Offline illrational
« Reply #2 on: September 10, 2011, 08:39:30 AM »
more pics...how severe a damage do you think i have with out having actually dimensions...i saw thread by jensen and he rebuilt his whole engine which looks like mine
Offline illrational
« Reply #3 on: September 10, 2011, 08:42:47 AM »
input would be appreciated
Offline Mcwilliams570
« Reply #4 on: September 10, 2011, 09:56:35 AM »
Doesnt look that bad to me about what mine looked like. The pistons and valve tops can all be cleaned thats just normal carbon build up I would think.
The thing that caught my eye is the second picture of the pistons. The piston that is on the outside it looks like the rings are fused or gunked up with stuff might just be the camera shot.
Not sure about the rust on the studs though.
You need to get the pistons and walls measured see if they are still within tolernce then go from there.
Im sure more will have more imput and have more suggestions.
Goodluck to you..
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline illrational
« Reply #5 on: September 10, 2011, 07:03:19 PM »
I ordered new valves, didnt think they would be so expensive and i found a diy auto shop so i cleaned everything up i could and also grit blasted....top, brackets, cylinder looks much better. What would you recommend i use to clean the carbon...will i also be able to use your method to clean the crbon build up inside the ports of the head?
Offline illrational
« Reply #6 on: September 11, 2011, 04:41:52 PM »
came across a thread dealing with Pamco ignition and think i may get the kit....have to pick up some calipers tomorrow so i know wether im just buying rings or a complete piston kit...crossing my fingers it will just be the rings...was so sure i was going to buy a tank seat combo from benji, that pinas design is gansta, but not reading all teh issues im not too sure. Anyone that replaced their piston rings did they need any specialty tools?Right now i just want to have her running by the end of september.
Things to do:
Measure pistons: in tolerance replace rings or out of tolerance replace pistons and then i probably should go with bigger size to get more power decision decisions
Measure head: check for distortion
Replace valves
Adjust tappets
Put carbs back together
Replace strainer in oil tank
Oil change
Offline illrational
« Reply #7 on: September 11, 2011, 05:18:43 PM »
just looked at my carb arm links and realized that three are the same and one is different...should i have all of one kind and i wonder if this contributed to me not running with out the choke on?
Offline illrational
« Reply #8 on: September 12, 2011, 05:54:26 AM »
Thanks Matt...is your bike running?the rings arent hummed up but ill wd40 studs and hit with wire wheel.dis you use special tool to put piston rings in
« Reply #9 on: September 12, 2011, 07:10:52 AM »
Here is a link of piston rings and what people have done to get them in/out. http://forums.sohc4.net/index.php?topic=57478.msg622214#msg622214.
I have a 74 550 that I am in the gathering parts/ideas and thinking wtf have I gotten myself into stage.:)
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline illrational
« Reply #10 on: September 12, 2011, 08:07:12 AM »
U know that feelin the post about the low compression addressed piston rings and got 125 has me feeling pretty good right now
« Reply #11 on: September 12, 2011, 10:14:39 AM »
Good to hear :)
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline lucky
« Reply #12 on: September 12, 2011, 10:31:23 AM »
I am 62 and started working on Hondas in a dealership when I was 16.
That engine does not look that bad at all.
Sometimes you take a cylinder head off and there will be broken piston rings or even a hole in the top of a piston. One good reason to put rags under the pistons BEFORE you pull the cylinders all the way off the pistons so pieces do not fall in the crank case.
NEVER clean the top of a piston with a wire brush. It will ruin the piston.
You can scrape the top of the piston but just do not use a wire brush on it.
NEVER put the piston in a vice to hold it. (I have seen it done)
You always have to measure piston to wall clearances with the right tools BEFORE you can determine if you will be able to reuse the pistons. They have to be measured the right way. Most of the time you will not want to reuse the pistons because the ring lands get rounded off on the edges. Also remember the letters (T) on the piston rings face UP.
When you take piston rings out of a box do not turn them over or mix them up.
Many people play around with them and then cannot tell which is the top ring and 2nd ring.
I would never put photos on the internet and let people tell me if it is bad or good because many on the internet have no experience. You need to go to a machine shop and ask a trained engine builder about a piston.
You have to interface with the real world. Just my opinion.
Also this gives you the chance to become friends with a machinist that can teach you a lot of things. That is how I learned.
One more thing....
Mark all pistons positions, and which way faces forward. Wrist pins on Hondas may be offset.
« Last Edit: September 12, 2011, 10:36:31 AM by lucky »
Offline illrational
« Reply #13 on: September 12, 2011, 10:40:20 AM »
Lucky, could i soak in carb cleaner to get rid of most of teh carbon and wash it down with water put it through the parts solvent cleaner wash it off with water again and then hit with grit blaster?
Offline illrational
« Reply #14 on: September 16, 2011, 09:26:22 AM »
the carb cleaner worked really well after soaking all night on the piston......heres updated pic of some cleadned up parts using parts solvent and grit blaster...also got my first new part in mail....Pamaco ignition kit....eliminated the points and came with two new coils....putting the coils in the same spot is going to take a homemade bracket from home depot with some bending and drilling but should turn out cool
Offline illrational
« Reply #15 on: September 16, 2011, 09:27:12 AM »
continued
Offline illrational
« Reply #16 on: September 16, 2011, 09:27:46 AM »
continued again
Offline illrational
« Reply #17 on: September 16, 2011, 09:28:39 AM »
Oh considering redoing the wiring to get rid of som eof the mess take a look at this....some say this might be normal....any one concur?
Offline illrational
« Reply #18 on: September 17, 2011, 07:25:43 PM »
guess i better update for prosperity....went to the diy auto shop today and put more parts through part solvent and sand blaster...have rear of bike completely torn down....got tools i ordered from lisle today which was surprised and got me amped to work but still couldnt remove valves with their tool so not im going to try one from jc whitney....still need to remove casket from crankshaft case and was going to wire up ignition kit but figured i already have bike apart i might as well get the frame done...havent decided on color although i was thinking red...pistons are clean although a little discolored....got gasket kit but waing on piston rings, oil strainer, filter and valves....end of next week....i am so jealous of dudes on here that have full garage to work in...ive only been at it a week or two and i feel like ive gotten no where....im going to chrome my parts or should i cay polish the hell out of them...i need to get the engine out of the fram and i have to do by myself which i know will be a #$%* if any one has sugegstions i woudl appreciate it
« Reply #19 on: September 18, 2011, 08:06:44 AM »
http://forums.sohc4.net/index.php?topic=94761.0. Pretty much what i did to mine lay it down and came right out..
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline illrational
« Reply #20 on: September 21, 2011, 05:55:53 PM »
i got my engine out by accidentally taking bike off the center stand taking out screws and just lifting it out.....i got my new inlet valves, oil strainer, piston rings and spark plugs....looked through my gasket kit to see if i had all teh gaskets i would need....put strainer in and tightened up oil pan after i cleaned it as good as i could...next step should be putting piston rings on and probably getting my head and frame powder coated...having trouble gettting my exhaust gaskets or should i say exhaust rings out of the head the carbon is so deep
Offline illrational
« Reply #21 on: September 23, 2011, 11:10:05 PM »
Well I ordered a polishing kit for engine and stainless parts from eastwood. Also realized no need to open case but will blow it out and buying engine jack that will afford me ability to soda blast and polish. I need to order my new valves and i forgot.
Offline illrational
« Reply #22 on: October 01, 2011, 01:42:19 PM »
fckn aye still havent ordered exhaust valves but did order bore gauge oil seals orings and misc tools....actually did split cases and will replace all the above mentioned parts... found what turned out to be a moot issue with my upper crank case according to dave...heres some pict because who doesnt like pictures..also realized that i missed two oil seals for engine and will order oem seals for forks which i took apart today and some day will upgrade ...Matt im pretty sure youre the only one folloeing this build so ill post pics after i compress all and have some lasgna
Offline lucky
« Reply #23 on: October 01, 2011, 01:49:08 PM »
That is how pistons look on a used engine. Nothing unusual. Do you think used pistons look all shinney and polished? I do not see a problem.
Even the valves look normal for a used engine. No chunks of carbon,no burned edges,no cracks ,nothing unusual.
« Last Edit: October 01, 2011, 01:51:29 PM by lucky »
« Reply #24 on: October 01, 2011, 01:50:15 PM »
Aye lasagna and BEER ;D Well I finally got my pistons out and got everything measured is all within clearence. Going to do a hone and and new rings and start buttoning it up see how it goes. Work has been killing me 60+ hours this week and looks like the same for next week  :'( Sounds like yours is coming around alright..
Matt
« Last Edit: October 01, 2011, 01:52:01 PM by Mcwilliams570 »
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
