Author Topic: Headlight stopped working  (Read 2080 times)
drainyoo
« on: May 09, 2006, 09:53:49 AM »
So I fixed all the obvious issues on the bike and now out of nowhere the headlight is freaking out on me. It will work fine all day then all of sudden stop working. Then it will come back on the next day. It acts very weird. When it isnt working it sometimes goes on for a second when Im starting the bike and it seems like the battery dies for the second.
Not sure what this is. Any idea?
Offline byidesign
Re: Headlight stopped working
« Reply #1 on: May 09, 2006, 10:32:57 AM »
check all your fuses, and the holders
   {nice clean+tight}
    if fuse looks iffy replace it    clean Hi-lo switch contacts
    on handlebar, then check  connections to
    headlight,{behind headlight } and to the start/run/lights, relay next to battery
       Does tailight go out too?
             Hope it helps
                  Bruce
82CB650SC,80CM400
drainyoo
« Reply #2 on: May 09, 2006, 10:37:41 AM »
   {nice clean+tight}
             Hope it helps
                  Bruce
Thanks Bruce.
No just the headlight, all the other lights work perfectly. Where do I find the fuses? Ive looked and cant seem to find em.
Offline byidesign
« Reply #3 on: May 09, 2006, 11:09:19 AM »
What model /yr bike?
      some are behind one of the the sidecovers,
        others {my cb650} are under a plastic panel
       on top of the steering stem.......
             Hope it helps
                      Bruce
82CB650SC,80CM400
drainyoo
« Reply #4 on: May 09, 2006, 11:12:26 AM »
             Hope it helps
                      Bruce
1975 CB200T
Offline byidesign
« Reply #5 on: May 09, 2006, 11:26:56 AM »
     If you don't have a manual,
      I would go to the
         Oldmanhonda.com website,
       and pull up the electrical diagram for it.
            That one could be behnd the light.
               Hope it helps
                       Bruce
82CB650SC,80CM400
drainyoo
« Reply #6 on: May 11, 2006, 01:11:27 PM »
Well I installed clubmans and by having to disconnect and reconnect the wires it seems to have fixed the problem. Guess it was just a loose wire.
Thanks.
