Author Topic: TEWS' 1975 550F build *****UPDATED 04/23/2012***** SHE RUNS! VIDEO  (Read 31685 times)
Offline Strapman
Re: TEWS' 1975 550F build *****UPDATED 01/11/2012*****
« Reply #50 on: January 13, 2012, 01:11:40 PM »
Tews, just saw your post...re rust removal from chrome....i used a process that worked really well compared to polishes/cleaners....first i bought some "never dull" and swabbed it on my rims and fenders, then i used a good grade (Heavy Duty) Reynolds Aluminum sheet that i bunched up lightly (for rims)-it countours nicely to the rim--- or folded for fenders, while the never dull was still wet, i began scrubbing---since aluminum is softer than chrome, no scratches and during the rubbing, aluminum oxide is released from aluminum that aids in cutting, the lubricity of the nver dull stuff helps and they came out well. I then cleaned them with a micro fiber towel to dry and polished with traditional chrome polish. I had tried all types of polishes before, even steel wool at 0000 grade caused chrome dulling. Coca cola, regular, not diet can be tried in lieu of the never dull too--the acid in the coke neutralizes the rust and the aluminum foil safely polishes.
Offline Tews19
  • I am no
« Reply #51 on: January 13, 2012, 07:07:15 PM »
Thanks strap. I will try that.
Made progress today as I got the engine in.
Unfortunately now that the frame is all blingin' the engine looks like I need to paint it. I will most likely remove it and paint. Installation didnt take me more then 10 min. Then I found out I need to send off my swing arm to get new bushings.
« Last Edit: January 15, 2012, 08:05:06 PM by Tews19 »
1970 Honda CB750 survivor.
Re: TEWS' 1975 550F build *****UPDATED 01/13/2012*****
« Reply #52 on: January 13, 2012, 08:04:58 PM »
Before sending off your swing arm, consider doing it yourself.
Lar recently did his...
http://forums.sohc4.net/index.php?topic=100274.25
Offline Tews19
  • I am no
« Reply #53 on: January 24, 2012, 04:06:23 PM »
I posted in the what you do today thread but here is my progress.... Member mikeKato is stoping by tomorrow to help me get her upstairs and put back together.
Where to start..Polished the front forks, chrome ears, rear fender, chain gaurd.... Got the front end on, then the rear tire on... Wanted to see how she looked so far. Then decided I am not going to paint the engine and put it in and try to get her done in a few weeks at latest... I tore off the front end, rear tire, carried to the basement... Tried to mount the engine and could not get the bottom bolt on the left side in.... Then it was pointed out I need to remove the swing arm as I did not put the chain around it first................ Then called it a day.
Offline lucky
Re: TEWS' 1975 550F build *****UPDATED 01/24/2012*****
« Reply #54 on: January 24, 2012, 04:33:16 PM »
You do not need to remove the swing arm.
Just take off the masterlink and put the chain on.
Do not get the O ring chain.
Iy requires special tools.
Just get a regular chain. It is totally reliable and easy to take on and off.
All of these young guys think they need an o ring chain. You don't.
With all of the modern chain lubes you spray them on ,and the next morning it is ready to ride. The lube goes inside the rollers and coagulates.
« Reply #55 on: January 24, 2012, 04:39:09 PM »
What are you doing for a seat?
Offline Mooshie
« Reply #56 on: January 24, 2012, 04:48:03 PM »
Mythbusters used aluminum foil and coca-cola to great success. It actually beat out chrome polish in their rusty bumper test.
I used wet aluminum foil.  It was amazing.  Just fold it up, get it wet and keep folding it until the foil is basically black and gone.  Then off to a new piece.  It works great on rust.  Never tried it with soda though.
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Offline Tews19
  • I am no
« Reply #57 on: January 24, 2012, 04:50:51 PM »
Depending on the length, I want to put a Daytona replica on it from Roc city. I have to wait til I get the tank back and then off to my friend to match the paint of the tank to the seat.
Offline Tews19
  • I am no
« Reply #58 on: January 30, 2012, 01:02:57 PM »
Got a rolling chasis! Progress!
Offline Mcwilliams570
Re: TEWS' 1975 550F build *****UPDATED 01/30/2012*****
« Reply #59 on: January 30, 2012, 01:10:34 PM »
Looking good so far. On your fork ears what are you going to do with the little hole that the reflector light went into. I am still trying to figure out what I want to do with it. I dont want to put them back on just might put a small starwars band aid on it for now :)
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Tews19
  • I am no
« Reply #60 on: January 30, 2012, 01:24:14 PM »
The refelectors go over the hole of the headlight bucket.  These chrome ears are not like the ones on my 750 where you have the little in the middle.
« Reply #61 on: January 30, 2012, 04:21:54 PM »
Tews - looks real good! Are you keeping the signals on? On a cafe?
Mcwill - to cover up a hole, consider a decorative license plate bolt, I used a chrome bullet shaped one on the holes in my polished triple tree [where the speedo bracket originally mounted]
Offline wedoo2
« Reply #62 on: January 30, 2012, 04:55:22 PM »
Are you sure you don't want to paint the motor?  I doubt that I got my motor completely clean,and the paint may chip off, but I have a whole can of the high temp stuff if I ever need to touch it up.  After all, you are in Wisconsin and it's going to be forever before you ride every day.  Although I did ride a little today.
I really like your frame.  Things are coming along fine for you and I am watching the progress.
Some days the sun is too loud.
Offline Tews19
  • I am no
« Reply #63 on: January 30, 2012, 07:48:53 PM »
I know I had to take a look at it again in regard to the engine. I really do not want to remove the forks, wheels to take out the engine. I will decide soon though. The engine would make it pop some more. Ahh #$%*.. If I can get a buddy out here I will probably remove the engine and paint it. There is a heat wave here in WI this week. 40 degrees.
I plan to get new turn signals. cafe style ones.
http://www.lockhartphillipsusa.com/store/home.php?cat=400
« Reply #64 on: January 30, 2012, 08:12:31 PM »
I wouldn't paint unless it was 60*.  Do you need signals?
Offline Tews19
  • I am no
« Reply #65 on: January 30, 2012, 08:14:28 PM »
Link listed below is where I will be ordering them from.
Offline wedoo2
« Reply #66 on: January 31, 2012, 02:53:56 AM »
Those turn signals are perfect.  One thing I noticed is that they have 3 wires and my signals have 2.  Since my lectrical skills are low, I had a moment of panic.  But I love them and I see them in my future.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #67 on: January 31, 2012, 01:12:28 PM »
wedoo, The 3 wire signals can be used as running lights in the front as well as turn signals (this was the stock setup on my '77). For rear signal applications or older bikes without front running lights you just don't use one of the wires.
Offline Tews19
  • I am no
Re: TEWS' 1975 550F build *****UPDATED 01/31/2012*****
« Reply #68 on: January 31, 2012, 02:52:24 PM »
Signals should be here in 4 days.
Things completed today...
cleaned/Polished the speedo and tach.
Cleaned/Polished the front fender
Stripped the caliper.
Installed the front fender, front caliper, speedo, tach, ignition and all electrical....... Bike should be done hopefully this weekend....
One hold up. I can not get the bottom bolt through the frame and the engine.
« Last Edit: January 31, 2012, 03:02:24 PM by Tews19 »
« Reply #69 on: January 31, 2012, 03:11:47 PM »
Your getting there man keep it up..
Thanks Stev-o will look into that....
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Tews19
  • I am no
« Reply #70 on: January 31, 2012, 03:14:07 PM »
Weedo, I ordered them today. I got dual filament series II for the front and the single filament for the rear. Danny hit it on the head with the explanation.
Offline Johnie
« Reply #71 on: January 31, 2012, 03:20:23 PM »
Tews...I just got done going through your build. Did not catch it before. Very very nice job there. You going to be done by spring? Awesome paint...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline wedoo2
« Reply #72 on: January 31, 2012, 03:53:09 PM »
You might post how you hook it up, if you have the original wire colors.  As soon as I started to read Danny's reply it hit me.  Not a bad idea having a bit more light back there.
Offline Tews19
  • I am no
« Reply #73 on: January 31, 2012, 07:25:07 PM »
Thanks Johnie, the plan is to have her done next week. Putting her back together is actually going smooth minus the lower bolt through the frame and engine. Now I am waiting for my side covers and tank from Johnny5.  The frame is Bengal Silver with clear coat PC.
I will post how the hook up goes. I ordered both dual filament but didnt want the extra draw to the charging system so I called them and they changed out one order.
« Last Edit: January 31, 2012, 07:28:01 PM by Tews19 »
Offline Tews19
  • I am no
« Reply #74 on: February 01, 2012, 02:00:19 PM »
Member MikeKato came over and helped me with the lower bolt. now I need to hook up the rear nud guard, fender, brake, carbs and airfilter.. Then hopefully VROOOOOOOOM
