Author Topic: 71 CB750 Headlight Wiring help  (Read 8134 times)
Offline Humble Pie
  • Seeley #519
« on: September 11, 2011, 06:15:29 am »
Ok the three wires for the bulb are
solid color
blue
green
white
Which wires from the main harness  go to what ?
also I have an after market headlight switch,, ( three plugs ) ,,which three wires on the main harness got to the stock switch ?
Thanks
Offline OldSchool_IsCool
  • Really feeling like an
Re: 71 CB750 Headlight Wiring help
« Reply #1 on: September 11, 2011, 06:20:50 am »
The answers you seek can be found here:
http://oldmanhonda.com/MC/wiring750K1.html
From what I see, it's blue, white and green all the way home!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Lostboy Steve
    • Lost Boy's Blog: Atomic Garage
« Reply #2 on: September 12, 2011, 01:58:04 pm »
I almost committed suicide over my headlight wiring. (not really) I pulled apart all my connections months ago and like an #$%* I didn't label anything thinking it would be easy to get back together.... well.... its still not together, but i did get a little sidetracked at the moment.
1968 Honda Z50
1977 Honda CB550K
1982 Honda GL1100i
2005 Yamaha Raptor 50
2009 Honda FourTrax Foreman Rubicon
2013 Yamaha WR250R
For my projects/activities: http://www.atomicgarage.net
KingCustomCycles.com
« Reply #3 on: September 12, 2011, 02:29:44 pm »
match the colors in a Honda harness.  Turn signals are the exception but even those have the properly colored bands on the wires.  Anyhow, +1 on oldmanhonda.com  I can play with his animated wire diagram for hours, well, maybe minutes. I like to use a contunity light for such things.  Select high beam, see which wire responds to the switch action, plug it into the connector, repeat.  Green is ground.
Offline CBNJ74
  • Sweep the leg!
« Reply #4 on: May 06, 2012, 11:59:26 am »
Bring this one back to life. Going through this nightmare right now. What about the green wires that are connected to the headlight bucket? where do they go?
1973 Honda CB750K
1983 Honda VF750 Interceptor
2005 Triumph Thruxton
2012 Ducati Monster 1100evo
« Reply #5 on: May 07, 2012, 04:06:12 pm »
Solid green is always ground. I assume you are talking about the two green wires bolted to the turn signal blocks.  Attach those to the ground wire of the turn signal lamp.
Sure.
Is it hard?
bollingball
« Reply #6 on: May 07, 2012, 04:33:10 pm »
I took a single 14ga bucket grounds out to the frame at the coil.
Offline CBNJ74
  • Sweep the leg!
« Reply #7 on: May 07, 2012, 06:07:52 pm »
Yes, I've got two green wires coming in from the frame harness (I think). One has a three way connector the other has a four way female connector. The PO was in there before so who knows what's OEM and what isn't. Maybe I should post some pictures.
1973 Honda CB750K
Offline CBNJ74
  • Sweep the leg!
« Reply #8 on: May 08, 2012, 05:35:22 pm »
Ok here are some pics
These I did not unplug I assume they are correct?
The long black wires at the bottom are from the front turn signals. I think i remember them pluging into the dual female orange wires?
Right behind that light blue wire there's a single orange wire with a double female connetor with a  cover that is half white I assume one solid orange and one orange with a white stripe goes in there?
Here's where all the trouble started. which green wires go here? I have two from the headlight bucket. One for the tack light and speedo and a couple of others.
1973 Honda CB750K
Offline CBNJ74
  • Sweep the leg!
« Reply #9 on: May 08, 2012, 05:36:03 pm »
Ok here are some pics. Please note this is a for a 73 CB750K if it matters.
1973 Honda CB750K
« Reply #10 on: May 09, 2012, 02:31:18 pm »
The solid greens from the blinker stem bolts go to any of the solid green females. The solid orange and the orange with white tracer go to the hot side of the left dual filament turn signal bulb. Solid is the running light, tracer is the turn signal.  They do not both go to the dual female orange wire, only the solid orange goes there.
For the right turn signal, do the same thing only with the solid blue & blue w/ tracer.
Sure.
Is it hard?
Offline CBNJ74
  • Sweep the leg!
« Reply #11 on: May 09, 2012, 07:06:28 pm »
OK we're making progress thanks to you guys! here's the situation as of a few minutes ago. I have working signals with buzzer, horn and starter and signal indicator on instrument panel along with neutral and oil light.
What I don't have after plugging the headlight back in is: Lights, running lights and tach/speedo illumination.
Here's what it's looks like right now. That orange wire hanging there is a bit of a mystery as I've plugged it into different orange wired female plugs.
« Last Edit: May 09, 2012, 07:08:45 pm by CBNJ74 »
1973 Honda CB750K
