Author Topic: 1977 honda cb550k brakes (stock or modded)  (Read 1095 times)
Offline illrational
« on: September 12, 2011, 10:08:27 AM »
Let me know which and what u did to them
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #1 on: September 12, 2011, 10:19:50 AM »
I swapped in 750 forks, disk, caliper & fender. Also braided brake lines. I'm happy with the results.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline illrational
Re: 1977 honda cb550k brakes (stock or modded)
« Reply #2 on: September 12, 2011, 10:36:32 AM »
how do the compare to how the brakes were with the original setup....i was considering taking a caliper from a newer model bike along with new pads, lines and drilling my rotors
Offline chopped550
« Reply #3 on: September 12, 2011, 10:49:55 AM »
now that would really be illrational.
Offline illrational
« Reply #4 on: September 12, 2011, 11:13:55 AM »
lol you know there is a difference between irrational and illrational but point taken ;D
Offline underachiever
  • Squandering my potential since 1989
  • 77 CB550K
« Reply #5 on: September 12, 2011, 01:22:04 PM »
Drilled rotor, reversed caliper, new ceramic pads, braided stainless line direct to caliper, new nissin 1/2" master, new fender mount/brace.
In a straight line full on stop I can just get the front tyre to start making noise. Still too stiff at the lever though, should have gone to an 11mm master like I wanted but found this one cheap.
tony
Offline illrational
« Reply #6 on: September 12, 2011, 01:28:19 PM »
what about the brake light?reversed caliper?can you send a pic?
  • 77 CB550K
« Reply #7 on: September 12, 2011, 01:59:45 PM »
Brake light switch is in the lever, which allowed me to ditch the pressure switch and run a single brake line. Just made a new wire to extend the electrics for it up to the bar. As for the reverse caliper, and how to/whether to do it has been explained to death throughout the forum. Search for dual disc conversion and caliper reversal etc..
tony
Offline illrational
« Reply #8 on: September 12, 2011, 02:50:03 PM »
What's the benefit of reversing the caliper
  • 77 CB550K
« Reply #9 on: September 12, 2011, 05:13:20 PM »
As I said, the search function will help here, but in a nutshell, the braking advantages seem to be associated with reduced fork stiction which improves suspension performance under braking loads as the forks are pushed away rather than tucked under the bike.
The main benefits people seem to note have more to do with handling. By moving the caliper weight behind the forks and down, it seems to improve stability to some degree, to the point of possibly reducing the chance of headshake problems, and perhaps also reducing any wheel flop tendencies. I know my bike felt a bit more surefooted after I made the change and when I roll with my hands off the bars now, she tracks nice and true and steady.
A side note to this is that ALL modern bikes including the late 70's Honda's and onward position the brake calipers behind the forks. If on top and ahead was the right way, then that's how they'd be done.
tony
Offline illrational
« Reply #10 on: September 12, 2011, 05:23:15 PM »
Good point....u ever clean carbon off if your pistons
