Author Topic: 1978 cb750 Espresso  (Read 14445 times)
Offline the-wu
    • Portfolio
1978 cb750 Espresso
« on: September 13, 2011, 11:28:58 AM »
So it begins! This is not a full 'BUILD' but here's a place for me to document my progress with this bike. Will be cleaning up and adding my own flare to the bike.
This is the bike on day one looks pretty good as is!
Offline the-wu
    • Portfolio
Re: 1978 cb750 Espresso
« Reply #1 on: September 13, 2011, 11:31:31 AM »
Modifying the seat on the bike. The previous owner chopped up the tail end of the frame and made a short stubby seat. Now I’m stretching it back out so that it feels more proportional. Also get a better upholstery job done. Since I cant fabricate metal I’m gonna stretch it out with plywood then refinish the whole thing. Bondo time!
Offline the-wu
    • Portfolio
« Reply #2 on: September 13, 2011, 11:34:15 AM »
How the seat sits on the frame and over the wheel a little more now. Also shaped it so it sits underneath the fuel tank nicer rather than a big gap in between the seat and tank.
Offline hapakev
  • Your Standard
« Reply #3 on: September 13, 2011, 12:29:28 PM »
Much better look, IMO.  It makes the lines much cleaner!
Smoking Jack
1978 CB750F(ish)
Offline lone*X
« Reply #4 on: September 13, 2011, 02:30:39 PM »
Can't see a frame loop under the back of the seat.  Did the PO just chop it off without adding any support?  I have always been under the impression that the stock cross brace under the seat was insufficient to maintain rigidity once the rear section was cut off.  You may want to address that.  Nice bike to start working from.  Enjoy the trip.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline jaguar
« Reply #5 on: September 13, 2011, 03:09:29 PM »
yes the rear conector between the shocks is important, as it the front fender, or at least a front brace.
are those wheels drilled?
Offline the-wu
    • Portfolio
« Reply #6 on: September 13, 2011, 03:33:06 PM »
Thanks for the replies! and thanks for addressing the rear connector issue. What kind of problems will i have if i leave it like this? Would it be a Torsion (twisting) issue or is it the rear-end collapsing inwards?
Can i just drill the frame and put a rod in with nuts/washers? or does this need to be a welded piece?
Here are some pictures of the frame without tank and tail
And yes, the wheels are drilled (by PO)
Offline the-wu
    • Portfolio
« Reply #7 on: September 13, 2011, 09:23:46 PM »
Out with the old gauges and center cluster, in with smaller 2 inch speedo and tach. Cleans up the front nicely.
Offline lucky
« Reply #8 on: September 14, 2011, 07:13:04 AM »
Good job on the seat modifications. Like to see the finished result.
Be careful welding around those contact cement glue fumes!!!
I noticed you were wearing gloves but no gloves for the welding.
Do not wear the tight fitting mechanics gloves while welding. If they get hot that synthetic material will stick to your skin and burn.
Can hardly wait to see your finished seat. Thanks for posting.
Offline hapakev
  • Your Standard
« Reply #9 on: September 14, 2011, 08:41:02 AM »
Wow, never thought of mounting those from the ignition mounts, Looks great.  I made a dash panel from aluminum to mount mine.
Smoking Jack
1978 CB750F(ish)
Offline the-wu
    • Portfolio
« Reply #10 on: September 14, 2011, 09:06:17 AM »
Thanks for the concerns lucky! Haha, actually I wasn't welding. Just filing off the screws that were poking out. But note taken, good tip! The seat is well on its way now, once i get my photos organized i will keep you guys up to date!
Thank you! yeah we were playing around seeing where it fits best, there is a slight 'tilt' on the gauges, but i can live with that. it fit nicely! We moved the choke down to another slot to make room.
Pod filters cleaned up nicely!
Offline hapakev
  • Your Standard
« Reply #11 on: September 14, 2011, 10:13:30 AM »
Oh yeah, didn't notice that.  Bike looks good man, what are you're other plans?
Smoking Jack
1978 CB750F(ish)
Offline the-wu
    • Portfolio
« Reply #12 on: September 14, 2011, 10:51:36 AM »
Thank you! I'm mostly just going to be toying with the cosmetics, give it a new paint job, clean/tune/maintain it and get it on the road!
Here we lowered the bike with shorty rear shocks and pushed the tree area lower by a few inches. Looks WAY nicer! i like how the rear hugs the tire nicely. There will be no passengers or heavy load so hopefully the shocks will be fine.
Offline jaguar
« Reply #13 on: September 14, 2011, 12:56:41 PM »
you might not have know but alot of the time lowering a bike like that effects the handling in a bad way.  defiantly limits the clearance in turns
Offline the-wu
    • Portfolio
« Reply #14 on: September 15, 2011, 11:38:29 PM »
Ah, great point. No, i didnt think of this. will be keeping an eye out to test my turn clearance. thanks for the tip!
and now for some pictures!
cleaning the carbs
Starting paint for the tail. bondo, sand, prime, sand, color. Going to wetsand after this and clearcoat. Now you see why the bike is called espresso?
Offline yellowbirdrs
« Reply #15 on: September 16, 2011, 11:12:42 AM »
nice work on the carbs, great can paint work keep on the good work and don't forget to post the progress
X/A
Summer 2011
Offline the-wu
    • Portfolio
« Reply #16 on: September 22, 2011, 12:07:49 PM »
Lots of progress with the paint job. This is a rattle can job, will be coating it with spraymax clear coat and lots of wet sanding in between. I was skeptical at first, but I'm really happy with the way it's turning out!
Offline lucky
« Reply #17 on: September 22, 2011, 02:33:10 PM »
You are doing a great job on detailing that bike!
It also helps you to get to know the bike.
I still want to see that seat when it is all done.
Get a good upholstery job.
It is well worth the dough.
There is no reason a rattle can paint job can't look good.
Just remember that spilled gas can take the paint off.
Put lots of clear coats, and if you spill a drop of gas on it do not wipe it off ,just leave it alone. After months go by it gets more resistant to gas spills.
« Last Edit: September 22, 2011, 02:35:46 PM by lucky »
Offline the-wu
    • Portfolio
« Reply #18 on: September 23, 2011, 11:10:36 AM »
Here's what it looks like with body mounted! It's really coming together now  :)
Sent the seat out for upholstery, supposed to be getting it back soon!
Offline jaguar
« Reply #19 on: September 23, 2011, 01:58:37 PM »
cool color
your VW?
any info on those rearsets?
Offline hapakev
  • Your Standard
« Reply #20 on: September 23, 2011, 11:32:12 PM »
Looking sweet man!
Smoking Jack
1978 CB750F(ish)
Offline d1000rr
« Reply #21 on: September 25, 2011, 12:32:39 PM »
awesome!
Offline the-wu
    • Portfolio
« Reply #22 on: September 26, 2011, 01:46:05 PM »
cool color
your VW?
No, thats my coworkers 70 beatle. He's been helping me out on the bike so i park it at his place haha
Got my seat back! looks amazing, was done by a local auto upholstery shop.
This is about as much work as i want to put on it so far. Now it's getting some road-time =)
I'll take nicer photos of it soon!
Offline immortal
    • 1976 CB750F "Pegasus bike"
« Reply #23 on: September 26, 2011, 07:07:52 PM »
wow it looks great, how about a youtube video?
Sometimes...the hard thing and the right thing are the same thing!
1976 CB750F "Pegasus Bike"
http://forums.sohc4.net/index.php?topic=80492.0
Offline hapakev
  • Your Standard
« Reply #24 on: September 27, 2011, 08:02:19 AM »
Awesome! The seat looks great, actaully the whole bike does.  What shop did the upholstery and what'd it cost, if you dont mind saying?
Smoking Jack
1978 CB750F(ish)
