Author Topic: 1978 CB750 carbs (keyhole) style  (Read 3348 times)
Offline lucky
« on: September 15, 2011, 10:45:05 AM »
I was going through this set of carbs cleaning and replacing float needles and checking the jets and noticed that the idle jets are pressed into the carb. no way to get them out
I ran a .008 thousandths guitar wire through them to see if they were clogged and there was No resistance at all. I am wondering if they could still be clogged and if there is some way to get them out of the carb body. Anybody have experience with this type of slow jet?
Offline rklystron
  • I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
Re: 1978 CB750 carbs (keyhole) style
« Reply #1 on: September 15, 2011, 10:54:23 AM »
 Use a small vise grip and gently twist as you pull up. They will come right out.
1970 CB750 K0 (Bought in 73)
1972 XL250 (Bought new in 72)
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
1982 CBX1000 Pro-link
1975 CB750 DRAG BIKE
1977 Custom Built CB750 Sturgis Bike (GL front end).
1977 CB750 F2 (Big Resto)
1977 CB750A (Auction Buy)
1978 CB750 K8 (My San Francisco ride)
1984 VFR750 (Bought New)
« Reply #2 on: September 15, 2011, 10:59:50 AM »
Twisting removes more metal then you want.  Best to avoid making the hole bigger or the jet smaller.  Less risk of them falling out latter.
Pull them straight out, as that is the way they were installed.
It called a swagged fit, or swage fitting.
Offline lucky
« Reply #3 on: September 15, 2011, 12:20:49 PM »
Thanks.  Thank you both for responding!
I had not encountered that style before (I do not like them by the way), so I was worried that they could break off or distort.
I was having trouble getting my engine to start and idle. I had some starter fluid and the engine would respond for a few seconds with starter fluid so I knew this actually was a case of the engine not getting any gas. And sure enough when I got the idle jets out they were clogged.
They were 35's ad I used a .013 steel guitar string to clean them out.
Now I have a good feeling that it should start and idle.
Offline lucky
« Reply #4 on: September 15, 2011, 03:59:38 PM »
If I am running pods and 4 into 1 exhaust, do you think I will need larger idle jets or drill them out?
How many turns on the pilot air screws? I have them out 1.5 turns now.
My needles have no adjustment. Should I add one brass .030 shim?
BTW my 4 into 2 into 1 exhaust has a muffler.
« Last Edit: September 15, 2011, 04:02:53 PM by lucky »
