Author Topic: Cleaning bullet connector's female side  (Read 7498 times)
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« on: September 15, 2011, 06:06:46 PM »
It's easy to remove corrosion from the male side of bullet connectors, but the female side has always frustrated me. Stumbled on by far the best tool I have found for this. A small bore .17 caliber brass rifle cleaning brush avaiable for a few bucks at sporting goods stores has a tapered end small enough to get the brass bristles all the way into the female connector. Some finger rotation of the brush and you're quickly down to clean bare metal. Plug it back into the emery cleaned male end and the connection will be primo again.
Offline grcamna2
Re: Cleaning bullet connector's female side
« Reply #1 on: October 21, 2011, 08:03:25 PM »
Thanks for your post...I have tried a .22 cal. in the past & it was always too big;can I find a .17 cal. bore brush as you have described in any local department store(Walmart,etc.) or do I have to go to a specific type of gun store ?
Offline Eddie
« Reply #2 on: October 21, 2011, 08:08:34 PM »
I used Tarnex with good cotton pipe cleaners...then flush with dentured alcohol. Then hit with a dose of Deoxit..
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #3 on: October 21, 2011, 08:23:59 PM »
Just today I was looking at a big greasy ball of my wiring and thought to just ..dip..into some of that air conditioning coil cleaner stuff. It almost etches the aluminum it cleans so hard.
I will try this .17 bullet technique first though. I love adding new tools to my box O tricks, and tired of sketchy chemicals in my basement. Thanks
Offline Danno
« Reply #4 on: October 21, 2011, 08:25:03 PM »
walmart carries a small bor gun cleaning kit bill not too expensive I think I paid 14.00
Offline CoachDoc
« Reply #5 on: October 22, 2011, 08:13:55 PM »
I found the .17 cal size at Big 5, a local sporting goods store chain. Any gun shop should have them as well.
Offline hapakev
  • Your Standard
« Reply #6 on: November 21, 2011, 10:16:50 PM »
Recall how much at Big 5?
Smoking Jack
1978 CB750F(ish)
Offline CoachDoc
« Reply #7 on: November 23, 2011, 01:12:45 AM »
Dirt cheap- just a few bucks if I recall correctly. I bought 3 when I saw how little they cost.
« Reply #8 on: November 23, 2011, 04:23:13 AM »
Wally world should have it
Offline hapakev
  • Your Standard
« Reply #9 on: November 23, 2011, 12:22:27 PM »
Nice, I am sure I will be there this weekend  ::) Can't wait to check it out.
Smoking Jack
1978 CB750F(ish)
