Author Topic: F1 - cb400 front brake caliper  (Read 1222 times)
Offline JoeHip
« on: September 16, 2011, 07:53:11 AM »
F1 and '75 or '77 cb400 front brake caliper...are they the same and thus interchangeable?
'76 750F1
Offline JoeHip
Re: F1 - cb400 front brake caliper
« Reply #1 on: September 18, 2011, 09:18:26 AM »
come on guys ;)
'76 750F1
Offline Bodi
« Reply #2 on: September 18, 2011, 08:41:41 PM »
I think the 750 and 400 calipers are different. I'm not sure though. I suppose you're thinking of buying one from a picture? If you have both you can compare them side by side, there's no magic... if the bolt holes and pistons align and the things are the same size they are most likely identical. If you're talking about a CB400F1: all CB400F, CB350-4, and the disk brake 350 twins (CB350G?) used the same caliper. The 80's and 90's CB400F SuperFour and CB-1 are totally different.
Check a parts site to see if the two models have the same caliper part number if you don't have both. Different number = different part, Honda used a lot of carryover parts and never used a new number for an identical part for a new model in my experience. There are "non-400" parts on a 400 here and there, the "model code" middle 3 numbers in the part number identify the first model a part was used in.
Offline Danno
« Reply #3 on: September 18, 2011, 08:48:41 PM »
the only thing that is different is usually the bracket
Offline JoeHip
« Reply #4 on: September 29, 2011, 12:26:22 PM »
thanks for the info guys, i already have 3 different ones at home so i'm just gonna look harder to find an F1 caliper
'76 750F1
Online Deltarider
« Reply #5 on: September 29, 2011, 12:34:56 PM »
Hi Brabo,
Why not check the parts lists or consult Quick Part Look Up in a site like http://www.motogrid.com/pages/parts/viewbybrand/7/default.aspx. ?
CB500K2-ED Excel black
Offline JoeHip
« Reply #6 on: September 29, 2011, 01:47:51 PM »
brabo? niet schelden, ik woon er alleen en ook nog 's niet uit vrije wil ;)
'76 750F1
