Author Topic: 76 750 A shifter seals  (Read 1373 times)
Offline Chuck Hahn
« on: September 17, 2011, 05:45:27 PM »
I ordered the new seals for  around the shifter shaft and the other shaft that is linked to the shifter. They are leaking and my question is this.  Can I pry the leaking ones out with the cover on the bike or do i need to remove the cover to replace these 2 seals??
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: 76 750 A shifter seals
« Reply #1 on: September 18, 2011, 06:41:22 AM »
Drill small holes in the seal and thread a couple drywall screws into it. Then yank the seals out. Be careful not to damage the case or shaft when you drill.
......Paul
Offline Chuck Hahn
« Reply #2 on: October 01, 2011, 02:12:40 PM »
Paul..its been a while since I have been online and was just checking in. Digger is doing the carbs right now and soon as i get 2 seconds to breathe I will do the drywall screw therapy.. Thanks for the tips.
