Author Topic: Removed stator cover, now NO POWER  (Read 1982 times)
Offline Mr. B
« on: September 18, 2011, 08:11:59 AM »
'76 cb750f, removed stator cover and gear box cover for polishing, marked wires, reassembled, now no power when I turn the key.  Bike ran great before, I have marked the three yellow wires and tried every possible combo, green to green, off white to off white, battery is good, fuses under left cover are all good.  Am I missing something simple?  Did I fry something?  What is the most likely culprit?  Where should I begin?
thanks
KingCustomCycles.com
Re: Removed stator cover, now NO POWER
« Reply #1 on: September 18, 2011, 08:47:17 AM »
Unrelated failure of ignition switch?  There are only a small number of wires and components that can cause a complete failure.  See if power is coming off the battery to the switch then work your way out from there.  I like to use a light bulb and a pokey metal stick thingy to check where power is, and is not, within wires.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: September 18, 2011, 09:08:19 AM »
I'd still suspect the main fuse.  Just because it looks good doesn't mean it is good.
« Reply #3 on: September 18, 2011, 09:45:31 AM »
Verify your visual observations with an electrical test instrument.
Offline lucky
« Reply #4 on: September 18, 2011, 04:10:32 PM »
Make sure of the wire color. White and yellow could get mixed up.
