Author Topic: Case splitting question  (Read 2746 times)
Offline illrational
« on: September 18, 2011, 01:05:39 PM »
Does anyone have list of special tools that they needed to remove all that was needed to split case? The reason im asking is because i assume those special tools wont be oem and i could use the heads up on where to get them from
Offline camelman
  • Man... Myth... Legend
Re: Case splitting question
« Reply #1 on: September 18, 2011, 01:11:08 PM »
No special tools are needed.  Just a decent socket set and a monkey wrench.  You'll need a torque wrench when you reassemble.  This should all be standard garage equipment.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline illrational
« Reply #2 on: September 18, 2011, 01:20:49 PM »
dont i need weight hammer or rotor puller ?
« Last Edit: September 18, 2011, 01:33:37 PM by illrational »
KingCustomCycles.com
« Reply #3 on: September 18, 2011, 01:41:36 PM »
Rotor puller might be handy to lighten the parts but not necessary for a case splitting.  A soft gasket scraper, a roll of paper towels, some baggies for parts, marker for labeling, all standard kitchen and garage stuff.  These SOHC's aren't like a new Chevy pick-up, or even a Harley, they are affordable and easy.
Offline WarwickE36
« Reply #4 on: September 18, 2011, 01:42:27 PM »
I just split my cases on my 550.  You dont NEED a slide hammer or puller for anything specifically, the primary will come out without one.  You can also get the stator rotor off without one, a rubber dead blow works well.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
« Reply #5 on: September 18, 2011, 01:55:41 PM »
Warwick, you got lucky on that rotor coming without a puller, my guess is it was not properly torqued at some point.  Most are a witch with a B.
Offline WarwickE36
« Reply #6 on: September 18, 2011, 02:54:30 PM »
Its all in the wrist.  If I remember correctly I did mine with the Crankshaft out.  A couple of swift blows on either side and it went clanking down on the workbench.  There was a lot of drinking during my rebuild so who knows what really happened.
2004 SV650s
Offline illrational
« Reply #7 on: September 18, 2011, 03:50:33 PM »
Thanks fellas....i have the top end off and im not sure if i shouldnt take a look at the bottom end before i put everything back together
Offline illrational
« Reply #8 on: September 18, 2011, 04:07:56 PM »
BTW could leave bike on center stand and rove boty tires and fork?
Offline nokrome
« Reply #9 on: September 19, 2011, 07:47:10 AM »
dont forget a good impact driver for those stuck/stripped case screws,
  the special clutch nut socket comes in handy too but i guess you could get away with a screwdriver and a hammer
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
Offline illrational
« Reply #10 on: September 22, 2011, 08:10:16 PM »
i cant budge that generator rotor
Offline MidnightLamp
  • Wrenchy wrenchy wrench!
« Reply #11 on: September 22, 2011, 08:28:08 PM »
Get the puller. It's worth the cost usually, rotors can sometimes be a real pain to get off.
Don't: Pry, pull, or hammer the rotor off as you might damage/warp it.
'75 CB750 - Racer
'69 CB350 - Racer
'68 Enfield 350/440(flat top) - Steet
'54 Enfield 350 - Resto
'74 Commando 850 - Restomod
'67 Enfield 750 (TT7) - Resto
Offline illrational
« Reply #12 on: September 23, 2011, 05:37:30 AM »
Which means I now have to wait .....damn I wanted to blast this week n powdercoat next week
« Reply #13 on: September 23, 2011, 05:46:58 AM »
heating, or hammering, a magnet will destroy it very quickly.  I proved this to my aviation students one day with a Gaus meter and a hammer.
« Reply #14 on: September 23, 2011, 05:52:46 AM »
Don't forget beer.
Offline illrational
« Reply #15 on: September 23, 2011, 06:06:50 AM »
Is there an alternate readily available tool I can use from one of the automotive stores
« Reply #16 on: September 23, 2011, 06:22:42 AM »
ill post a picture of the tool you need for the 500/550 rotor puller tool in the morning,the rotor itself isnt a magnet,,its a dead thing untill the field is energised,,dont hammer it though,you dont want to unbalance it.
« Last Edit: September 23, 2011, 06:31:31 AM by dave500 »
« Reply #17 on: September 23, 2011, 06:28:38 AM »
It would help if you said what bike as 750 and 500 differ
Offline illrational
« Reply #18 on: September 23, 2011, 07:23:22 AM »
Sorry I thought I specified bike....its 77 cb550k ....I found a spot for getting the tools relatively cheap most were around 10$...the valve tool and bearing tools were expensive
« Reply #19 on: September 23, 2011, 06:55:54 PM »
heres the puller for the rotor,,its just a 15mm fine thread bolt,it winds into the purpose made thread in the rotor,do it tight then knock it with a hammer,maybe tighten it again and one more knock and the rotor falls of the taper.
Offline akinz
  • life is a one lap race
« Reply #20 on: September 23, 2011, 07:11:54 PM »
Dave used the same tool I did.  ;D
My Clymer manual stated in the steps of splitting the cases, you had to remove the rotor. WRONG If you are having trouble, stopped your progress because of this don't worry, you can carry on removing the bolts which hold the cases together.  Just make sure you remove the one that's under the oil pan
77 CB550k, Finally completed after 3 long years of a complete teardown and rebuild/modification
77 CB550k, on the backburner to turn into a vintage race bike
79 CBX 1000 an absolute classic I just aquired
2005 Yamaha Raven R6 my street and trackday ride
« Reply #21 on: September 23, 2011, 07:21:09 PM »
you will need to remove the rotor though to replace the main seal.
Offline illrational
« Reply #22 on: September 23, 2011, 07:24:54 PM »
lmao.....one hell of a tool there dave!!!!
Offline akinz
« Reply #23 on: September 23, 2011, 07:28:31 PM »
Yes
