Support the site. Your contributions keep this site running.
Before you split the case, you might try pulling off the shifter cover and taking a look the the shift mechanism.
That flat head screw goes into the center of the shift drum, and locks the plates and pins to the drum. The shift pawl engages the pins to rotate the drum. With that screw missing, the pins flex around, and the drum doesn't rotate as far as it should.
The screw that I took out was "shiny and new" with a rounded top
