Author Topic: Top End Fitment  (Read 587 times)
Offline livetoskate
  • "Get busy living or Get busy Dying"
Top End Fitment
« on: September 21, 2011, 06:20:31 PM »
I have a 73 cb750 and am wondering what top ends would bolt on my bottom end?
I believe 69-76 would bolt right on but am not sure. I am wondering because there is a very early model top
end that has been completely rebuilt and has a full new piston kit for sale in my area.
Any help would be great,
Thanks
78 cb750K , 73 CB750 x2, Yamaha dt360 & 250
Offline chewbacca5000
  • I polish covers!
Re: Top End Fitment
« Reply #1 on: September 21, 2011, 06:30:01 PM »
I have a 73 cb750 myself and I am wondering the same question as I got to replace the head gasket and would like the the latter year kit as it includes the rubber do hickeys that go around the dowls.
Offline livetoskate
Re: Top End Fitment
« Reply #2 on: September 22, 2011, 05:12:40 AM »
I have researched this more but still have no luck.
Offline wrenchmuch
Re: Top End Fitment
« Reply #3 on: September 22, 2011, 06:19:08 AM »
Rubber do hickeys came in some time in the K4 model . Any combo of head / cylinder from K1- K6 will work . If you find a K0 head it will work too but you might be better off selling it as its worth more than later heads . At some point the oil jet in the head was changed from a non removable type (early ) with a single hole to a removable type . The removable type has a stem drilled with holes across it as well as a hole along its length . If small debris blocks a hole on the later type there are others to allow oil through . In the early type if the hole is blocked , no oil .
CB750K1
CB750K4
Offline fmctm1sw
Re: Top End Fitment
« Reply #4 on: September 22, 2011, 08:56:29 AM »
This is talked about somewhere by sparty or TT or someone...  Let me see if I can find it...
*edit* Mike Rieck actually:  http://forums.sohc4.net/index.php?topic=369.msg42059#msg42059
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline livetoskate
Re: Top End Fitment
« Reply #5 on: September 22, 2011, 12:52:04 PM »
In that post Mike Rieck only talks about the later models. Thank you guys for the help though
