Author Topic: Leaking issues!!!!  (Read 639 times)
Offline dergs713
Leaking issues!!!!
« on: September 22, 2011, 08:21:01 PM »
Hey guys just got my 75 550, finally put together and ready to start when i switched on the fuel and out came a steady stream of gas out of my pod air filters..... no bueno.
Then took the gas of and tried turnin it over and it started and ran for about five mins.  Totally went through the whole bike motor and all. first breath of this baby in 26 years! Super pumped but i dont dig the waterfall of gas.... any ideas...?
Matt
Offline luap
  • LAWL
Re: Leaking issues!!!!
« Reply #1 on: September 22, 2011, 08:24:12 PM »
id  check floats
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline dergs713
« Reply #2 on: September 22, 2011, 08:29:38 PM »
The tubes off the bottom of the bowls were pouring as well...? Did i do something wrong..?
Offline ACVWguy
« Reply #3 on: September 22, 2011, 09:58:05 PM »
Adjust floats. It's easiest when you pull the carbs (and more accurate) but can be done with them installed. Set them at 22mm from the bowl sealing surface. Make sure not to compress the little spring loaded needle valve when you adjust them. The spring loaded rod should be fully extended when the floats are set. Otherwise you will have fuel starvation issues. I did.
My carbs were leaking from all 4 over flow tubes on my 75 550, but after a float adjustment, no problems. I also suggest lapping the needle valve against the brass orifice with a little polishing compound for a better seal after 35 years of corrosion.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #4 on: September 23, 2011, 12:47:16 AM »
+1 with checking floats but the float needles are probably sticking, not closing off the flow of fuel when the bowls are full. They will need to be cleaned or replaced most likely; then check the height of the floats.
