Author Topic: engine shuts off when handlebars are turned??  (Read 1144 times)
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
« on: September 23, 2011, 09:11:10 PM »
Anyone know where I can get a color wiring diagram for an '80 CM400T. My problem is that when I turn the handlebars, the engine shuts off. Anyone every have this problem, or know what it might be? I'm thinking the kill switch????
                                         Thanks, Doggie
Offline MoMo
  • Ride like you're invisible
Re: engine shuts off when handlebars are turned??
« Reply #1 on: September 24, 2011, 01:12:57 AM »
If all the electrics shut down it is probably a loose connection at the ignition switch plug. All Honda motorcycles use the same color code for the wiring... What is shutting down?...Larry
Offline hondaface75
« Reply #2 on: September 24, 2011, 05:03:51 AM »
If its blowing your fuses, something is grounding out in or around your headstock. Ask how I know :) If your fuses are fine, Id agree with it being a kill switch issue.
Offline Doggie
« Reply #3 on: September 25, 2011, 07:29:09 PM »
Fuses are ok..Going to swap complete handlebars from another bike. See what happens with then.
                                                             Doggie
