Author Topic: Tail light doesn't work....  (Read 1477 times)
Offline deebz
« on: September 25, 2011, 02:44:36 AM »
Like the title says, tail light doesn't work. Brake light works but tail light doesn't work when the headlight is on. I haven't opened my haynes manual yet...any ideas??? Thanks in advance.
Offline johnny
Re: Tail light doesn't work....
« Reply #1 on: September 25, 2011, 03:11:45 AM »
Check the bulb first. It's a dual-filament and could be blown. Check the connection under the seat leading to the tail light. If there are three wires, the green is usually ground and the other two are running and brake light.
1976 CB550K
1974 CB350F http://forums.sohc4.net/index.php?topic=81781.0
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: September 25, 2011, 05:01:49 AM »
check for 12v at the brown wire under the seat.  If there, check the bulb-there should be continuity between the side of the bulb and each filament.  If you do not have 12v at the brown wire, get back to us...Larry
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #3 on: September 25, 2011, 07:09:34 AM »
Check bulb, trace wires to verify connections. Happened to me last week.My ground wire on the tail light had come loose.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Tews19
  • I am no
« Reply #4 on: September 25, 2011, 07:26:30 AM »
Definately check the connection with the brown wire under the seat, trace it through the headlight and see if it connected..
1970 Honda CB750 survivor.
Offline deebz
« Reply #5 on: September 25, 2011, 03:48:15 PM »
Just a bulb haha thanks guys.
Offline scuba steve
« Reply #6 on: September 25, 2011, 04:32:50 PM »
just had this same problem on my bike, the brown wire was opened up from rubbing under the seat. electrical tape was a quick fix.
Offline johnny
« Reply #7 on: September 25, 2011, 08:38:23 PM »
What do I win?
1976 CB550K
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
Offline deebz
« Reply #8 on: September 26, 2011, 12:37:24 AM »
