Author Topic: 1979 cx 500 opinion?  (Read 1502 times)
Offline Vintage Esquire
« on: September 27, 2011, 06:23:02 PM »
I completed my CB 550 cafe project and I have been looking for a new cafe project.  I have been interested in a cx500 because of the horizonally mounted pistons (cool).
I have found a complete 1979 cx 500 for $100.  Unknown runner, but good shape overall.  I will rebuild the engine first myself so no big deal on the fact that its a non runner as long as the pistons aren't seized.
Does anyone know any differences between a 1979 cx500 and an '82 or '83 cx500 that I should consider?  The only thing I have noticed is that the 79 has one front rotor and the rims are different between the two.  Any other info would be helpful.
Thanks
Offline 78whiteorbs
Re: 1979 cx 500 opinion?
« Reply #1 on: September 27, 2011, 06:35:31 PM »
Buy it!
cafe build_0001.wmv
S1050923.AVI
great bikes and good power to weight ratio,liquid cooled is a big plus in the heat of summer . The one you see I got few years back and the dude I got it from used a screwdriver clamped to a jumper cable hooked up to his truck t start it (no battery, and the carbs where leaking!) was a wonder the sparks and the gas didnt go KABOOM! Still for 200$ bux ,twas a legit deal :)
I have a build thread on hear you can check ,also choppercharles.com is a great website . There is a dude there called Blindstitch that knows everything there is to know about CX's-  If you wanted a really cool one look for an 80's TURBO model ! Oddball cafe? YES!!!!!
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: September 27, 2011, 06:40:41 PM »
The CX/GL 500 are bulletproof motors, a bit slow but reliable as can be.  My daily rider is a 1981 GL500I, I would not hesitate to ride it anywhere.  The water pump seal is notorious for going bad-somewhere on the internet there is a step by step thread on using a Yamaha seal to cure the problem...Larry
Offline 78whiteorbs
« Reply #3 on: September 27, 2011, 06:43:38 PM »
forgot to mention the charging systems are know weakness the stators go bad and you have to drop the engine to replace them which isnt a big deal because there is no  subframe so unbolt and roll away. definately easier than wrestling a 750 out of a frame ! Also water pump seals leak replace those when you remove engine and enjoy- They really are great bikes. The steed of choose of English Mail Carriers back in the day. Affectionately refered to as "plastic maggots" for the fugly fairings.
« Reply #4 on: September 27, 2011, 07:16:32 PM »
Thank you for your advice.  I enjoyed the videos.  I forgot to mention that the VIN does not indicate it is a "custom" model, but the tank is the tank off of a custom.  IF it is a custom model, do you still think go for it?  I figure I can switch out the tank anyways.
Offline MoMo
« Reply #5 on: September 27, 2011, 07:32:01 PM »
Doesn't matter for 100 you cannot go wrong.  My .02...Larry
Offline 78whiteorbs
« Reply #6 on: September 28, 2011, 06:35:51 AM »
+1   ^
