Author Topic: Torque value: side cover bolts CB500  (Read 1694 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: September 29, 2011, 08:09:05 AM »
Been replacing all of the old screws on the motor with stainless Allen bolts. The instructions that came with the set said to use anti-seize (of course) and that the torque value for the 6mm ones is 4.4 ft/lbs. You know, the CB500 is a wet sump engine, so the RH side cover holds in the oil. Is 4.4 ft/lbs enough torque to keep it from leaking? Seems on the light side. But I recall reading something about there being lower torque required when using anti-seize. Is that right?
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Torque value: side cover bolts CB500
« Reply #1 on: September 29, 2011, 10:31:47 AM »
BTW it doesn't say in the Honda manual. Maybe in the Clymer or Haynes?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #2 on: September 29, 2011, 10:33:21 AM »
Lower torque required with anti seize is correct.  Get 'em snug, and if you see a leak, give 'em an extra snugging..
« Reply #3 on: September 29, 2011, 10:35:21 AM »
My rule of thumb on these is to use as little as possible. A good uh with a T handle. If they leak, give it a skosh more.
I've never seen a torque value or any other guidance.
PS: Greggo beat me to it.   :'(
Offline Greggo
  • Somebody's
« Reply #4 on: September 29, 2011, 10:37:07 AM »
I won!  I won the money!  Oh, wait...there's no money? :(
Offline crazypj
  • I'm brill, me
« Reply #5 on: September 29, 2011, 10:39:52 AM »
There is a torque value in manual, your looking at it wrong.
 It's a generic spec for 6mm screws.
 6mm bolts are 5-7 ft/lbs, screws will work at same torque but it's usually 4-6ft/lbs (working from memory, may be slightly off?)
The torque may be given in inch pounds
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #6 on: September 29, 2011, 10:40:29 AM »
Only bragging rights LOL!!!
Thanks fellas.
« Reply #7 on: September 29, 2011, 10:47:44 AM »
I'd agree with that.
http://www.salocal.com/sohc/tech/torquetable.htm
Scroll down to the pan screws. Quite a wide range. Roughly equivalent to a good "uh" with a T handle.  :D
Offline crazypj
  • I'm brill, me
« Reply #8 on: September 29, 2011, 05:43:59 PM »
Don't forget, the screws and bolts are measured by shank size not head/socket size (eg, 6mm bolt has 8 or 10mm head)
5.1 to 8 ft/lbs is quite a wide range for a small screw
« Reply #9 on: September 30, 2011, 02:13:57 AM »
i never torque any of the smaller size bolts,just snug them down then a pinch more,sometimes my elbow goes "click"at the correct torque.
