Author Topic: rubber sealant? hondabond? on my carburator slide  (Read 1267 times)
Offline Strictlycustom
« on: September 29, 2011, 07:16:54 PM »
Cleaning my carbs, wondering if I should put a similar type of sealant back on after cleaning. The first carb I cleaned had a blue rubber on all of the metal parts that showed through the rubber gasket, and there was also a liquid gasket type of material on the back of the rubber gasket you see in the picture. I have hondabond. Will that work?
Offline MoMo
  • Ride like you're invisible
Re: rubber sealant? hondabond? on my carburator slide
« Reply #1 on: September 29, 2011, 07:48:26 PM »
Nothing recommended at all...Larry
« Reply #2 on: September 29, 2011, 08:07:46 PM »
Any idea as to what the blue rubber sealant in the picture is?
Offline ABikeNamedTrouble
« Reply #3 on: September 29, 2011, 09:47:28 PM »
Just some kind of silicone, I think.  Definitely not Hondabond though, as it would be white.  I agree that nothing should be used on a diaphragm like that.  If it needs sealant, it needs replaced!
- Adam
1980 CB650c Custom
Keihin PD mechanical carbs
Stock air box and 4-4 exhaust
http://forums.sohc4.net/index.php?topic=97504.0
« Reply #4 on: September 30, 2011, 09:18:05 AM »
Thanks for all the help!
