Author Topic: IT LIVES!  (Read 1064 times)
Offline RustyStuff
  • If it aint broke, Fix it till it Is.
IT LIVES!
« on: September 30, 2011, 10:21:49 PM »
After 20 years of hybernation my dad and I got his CB650 running. It won't Idle without full choke, but we dident have and Airfilter on it and he could tell it was leaning out. He thinks a bit of crap might still be in the Idle circuts so hopefully it will clear out, takeing those carbs out and apart is a PITA. I was worried we had a dead Cyl ( lower compression) but it sounds good, no miss or odd sound.
No video, mabey tommrow.
Sounds great, alot louder than I expected. Has a Nice thump at idle. Doesnt sound like a sportbike which I like.
'80 CB650
Offline Danno
Re: IT LIVES!
« Reply #1 on: September 30, 2011, 10:27:00 PM »
the 650 has cv carbs on it you will want to soak them to get the circuits back and make sure the jets are all clean I usually run a bunch of sea foam for two or three tanks of gas when I get anything with cv carbs on it out of storage
Offline RustyStuff
Re: IT LIVES!
« Reply #2 on: September 30, 2011, 11:05:34 PM »
It's got Normal Keihin carbs.  I pulled the carbs apart and cleaned every passage and jet with carb cleaner, so hopefully if theres anything left it will disolve.
'80 CB650
