Author Topic: Gasket Removal- 550 clutch cover  (Read 1868 times)
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« on: September 30, 2011, 10:54:35 PM »
I recently pulled the clutch cover for the first time on my '74 550. It was extremely hard to get it off and when I finally did get it off there were remnants of the gasket and severely hardened sealer on both the cover itself as well as on the other face. These remants came nicely off the cover side after a soak in Chemdip, but the bike side (pictured) is driving me crazy. The material is hard as a rock and defying even a metal scraper, which I used reluctantly as a last resort. I imagine the case metal there is pretty soft, but could I safely use a SS wheel/brush in a Dremel to remove this stuff? Is there a paste like material that I could apply to soften these accumulations and facilitate removal? Thanks, guys.
Re: Gasket Removal- 550 clutch cover
« Reply #1 on: October 01, 2011, 12:35:49 AM »
carefully try some paint stripper.
Offline tommanos
  • 71 CB500
« Reply #2 on: October 01, 2011, 07:13:36 AM »
Use Jasco  paint and epoxy remover.
71 CB500
68 CL350
71 CL175
BMW R1100R
Offline WarwickE36
« Reply #3 on: October 01, 2011, 08:42:17 AM »
I used a right angle die grinder with a 3M roloc disc (aluminum flavor) on mine.  They also make a rubber version with finger like things that work well too and will not mar or scratch the case metal.
http://www.bing.com/shopping/3m-automotive-3m-7480-2-coarse-scotch-brite-roloc-surface/p/C2282FE9BAF1C82ECB83?q=3m+roloc+disc&lpf=0&lpq=3m%2broloc%2bdisc&FORM=EGCA&lppc=15
http://www.bing.com/shopping/3m-automotive-3m-7524-2-scotch-brite-roloc-bristle-discs-50/p/6BC7B553D2C85634FB46?q=3m+roloc&lpf=0&lpq=3m%2broloc&FORM=EGCA&lppc=15
and a razor blade and elbow grease for the hard to reach spots.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline CoachDoc
« Reply #4 on: October 01, 2011, 03:10:45 PM »
Thanks for the suggestions, guys. 2 votes for paint stripper so I got some of that Jasco product this A.M. and I'll try that first. I wish it was available in a gel form, but all I could get was liquid. If that doesn't work those 3M discs sound like a nice alternative.
« Reply #5 on: October 01, 2011, 04:37:24 PM »
youll get a better angle at scraping if you remove the clutch basket,youll need a pair of external circlip pliers.
Offline CoachDoc
« Reply #6 on: October 01, 2011, 06:46:38 PM »
Thanks, Dave. Without the clutch in the way it would be much easier to get in there, so that's what I'll do. Too bad I can't figure out a way to let that face soak in Chemdip. That stuff is noxious and probably carcinogenic but it removed the gasket material and sealer on the cover with ease.
« Reply #7 on: October 01, 2011, 10:07:44 PM »
on the 550s the lifter plate will drop away from the four screws as you try to reassemble it,,just use one of the long case screws to hold and pull it back so you can engage a screw or two cleanly without cross threading.
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #8 on: October 02, 2011, 11:19:03 AM »
my vote is for the rubber roloc pad. It doesn't hurt the aluminum.
video of it in action
http://youtu.be/2lM7IgqMAiA
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline CoachDoc
« Reply #9 on: October 02, 2011, 09:15:12 PM »
Wow, that video was amazing. It's hard to believe that a system that works that fast to chew up the old gasket won't damage the aluminum face. Any first hand experience with it? I notice that a right angle grinder was used to drive it. I know those things can put out 20,000+ RPM. I don't suppose a drill would be an effective alternative due to the much lower speed.
Offline CoachDoc
« Reply #10 on: October 02, 2011, 09:17:30 PM »
I couldn't help noticing how clean the gasket face is in your photo, Dave. How did you get it that clean?
« Last Edit: October 02, 2011, 09:28:14 PM by CoachDoc »
Offline DavePhipps
« Reply #11 on: October 02, 2011, 09:37:53 PM »
I used mine with a drill and it took a lot longer than the video.
It's pretty handy for cleaning carbon from pistons and combustion chambers also.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #12 on: October 02, 2011, 10:52:18 PM »
i used a scraper,,it wasnt bad on these cases,it depends what some po has used on the gasket aswell.
