Author Topic: Setting Static Timing on '74 CB750  (Read 16641 times)
Offline emitch
« on: October 03, 2011, 03:03:41 pm »
Can someone please breakdown how to set static timing for a '74 CB750? I've looked at a few resources and writeups from this site, other sites, and the shop manual, and I can say with 100% confidence that I am thoroughly confused.
I have no idea how to begin, so if someone out there can break this down for me in simple terms, I would greatly appreciate it.
Thanks.
Offline emitch
Re: Setting Static Timing on '74 CB750
« Reply #1 on: October 04, 2011, 02:12:00 pm »
bump
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #2 on: October 04, 2011, 02:19:38 pm »
Start by accurately setting the points gap on both sets of points. Do you have a 12V test light? This will give you the best indication of when the points are opening to set the static timing (should be at the F mark for the point set involved).
Offline emitch
« Reply #3 on: October 04, 2011, 02:44:40 pm »
My gaps are set to spec. I'll be picking up a test light later today.
Offline emitch
« Reply #4 on: October 04, 2011, 05:33:09 pm »
This is the part where im confused - at what points do i hook up the test light? Also, the light should come on when the timing plate is moved and im on the 1-4 index mark, correct?
Offline CoachDoc
« Reply #5 on: October 04, 2011, 05:46:44 pm »
Hopefully a 750 guy will jump in here if I'm wrong for your bike, but generally the points plates are stamped 1,4 and the other 2,3. There will be similar stampings on the rotor as you look into the viewing window. Thus there is an F and a T for 1,4, and similar markings for F and T for 2,3. Clip the light across the 1,4 points and rotate the crank clockwise by turning the center bolt on the timing plate. The light will light when the points just begin to open, which should be at the F mark for 1,4. To adjust you loosen the screws and rotate the entire timing plate until the timing is correct. Repeat the process for 2,3 but the adjustment process is slightly different, involving just moving the 2,3 points sub-assembly> Refer to your owner's manual for this. When done if you have an inductive timing light you can hook it up to the appropriate spark plug lead and do a timing check at idle; you can also check your spark advancer at 3000 RPM by looking for the " mark in the timing window. Hope this helps.
KingCustomCycles.com
« Reply #6 on: October 04, 2011, 05:51:12 pm »
The light is only used to indicate the exact moment the points open.  The light should have the alligator clip attached to the engine case or fins (ground) the pointed end (probe) should be touching the part of the point assembly that moves with the cam.  Points open, light comes on, F mark in the window.  Do this for 1-4 and 2-3,  start and enjoy.
Offline emitch
« Reply #7 on: October 04, 2011, 05:53:52 pm »
Thanks for that writeup. What do you mean by "clip the light across the points"?
« Reply #8 on: October 04, 2011, 06:04:25 pm »
"the pointed end (probe) should be touching the part of the point assembly that moves with the cam"
Offline caferacer750
  • yup it getting there
  • ride it
« Reply #9 on: October 26, 2011, 08:33:44 pm »
is it really that easy
« Reply #10 on: October 26, 2011, 10:50:45 pm »
Sort of yes, you tend to find that when you rotate the plate to set the timing the gap alters as well and it takes time and fiddling to get both the gap and the timing spot on, but if you spend the time and get it absolutely correct it will run better and next time you need to adjust the contact gap (as long as you dont change th econtacts) you can hook up the light and with the timing marks lined up adjust the gap till the bulb lights
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #11 on: April 24, 2014, 07:33:16 pm »
Once the timing is done, do you set the points again?
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #12 on: April 25, 2014, 05:14:16 am »
Points first, then timing.
That's how the book says to do it. Never hurts to check, though. Just in case. ;)
--Evan
1975 CB750K "Rhonda"
Offline goldarrow
  • one day, i'll be an
« Reply #13 on: April 25, 2014, 06:00:00 am »
No
CB550 K0
Offline iron_worker
« Reply #14 on: April 25, 2014, 10:39:36 am »
No
Personally, once the timing is set I go back and check the gap to make sure it is still within spec. If you're unable to get the timing set as well as the gap within spec then it means either you are running crappy non-OEM parts (happened to me and many others!) or your points are worn beyond their useful life. One other thing that can happen is that the points plate itself is a slightly loose fit between it's locating "posts" and can shift side to side which makes one gap too tight and one gap too loose (which also affects timing).
IW
