Author Topic: Need some advice on a engine stand  (Read 3584 times)
Offline bambuhiphop
« on: October 03, 2011, 03:26:08 PM »
Hey everyone,
I am going to start a tear down on my engine by the end of the year and could use some thoughts on a stand for the motor. I would like something a little more on the mobile side and also something that I can raise and lower. The engine will be built on it so it won't leave until it goes into the frame. I came across this and thought it could work:
http://www.harborfreight.com/500-lb-capacity-hydraulic-lift-table-94822.html
Anyone have any other ideas or thoughts on this matter?
Thanks Much as always.
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
Re: Need some advice on a engine stand
« Reply #1 on: October 03, 2011, 03:32:07 PM »
I know someone who has one of these as a lift for heavy crap like lathes etc. Works very well. But I wouldn't use it as a working bench for a motor. For less than that $$$ you can buy a purpose-built engine stand that you can use to turn the engine around..to work on top vs bottom. Or a milk crate, lift it with a mate and put it on a solid wooden bench.
It could also fall off that stand when u start brute force to lever off stuck bits.
Offline kerryb
  • Not a very
« Reply #2 on: October 03, 2011, 07:14:35 PM »
I recommend you see the tips and tricks section.  read the C-hook/engine stand post.  I made my C-hook from a piece of tubing from a junked excercise machine, it was free.  I finish my rotisserie as soon as I need one.  Got the engine stand on a HF coupon for $40.00.
« Reply #3 on: October 03, 2011, 08:43:00 PM »
Offline bambuhiphop
« Reply #4 on: October 04, 2011, 10:44:10 AM »
I read through the c-hook thread and I think that is the way to go. Just need to figure out how to drill the angle brackets. Not really setup for that.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #5 on: October 04, 2011, 10:47:53 AM »
I made one out of 2x4's. Worked great!
Offline CycleRanger
  • No comment about being an
« Reply #6 on: October 04, 2011, 10:58:16 AM »
Imho, there's nothing cheaper  (except 2x4's)  or more effective than this.
HF engine stand, four pieces of angle iron and some threaded rod.
Offline lone*X
« Reply #7 on: October 04, 2011, 11:24:22 AM »
I also have the HF $40 special and have my 550 motor on it now.  Works great.  Only downside is if you need to split the cases, can't do that with it mounted to any type of stand.  Works great for top end and cylinders work and for detailing the engine.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline CycleRanger
« Reply #8 on: October 04, 2011, 12:10:36 PM »
Actually isn't there a thread here somewhere where someone used two engine stands to build a "Siamese" stand to hold the engine while the cases were split?
Offline bambuhiphop
« Reply #9 on: October 04, 2011, 01:15:18 PM »
Found this great thread
http://forums.sohc4.net/index.php?topic=58210.0
Once I figured out how to make the angle adapters this is the approach I am going to take.
Offline luap
  • LAWL
« Reply #10 on: October 04, 2011, 02:12:01 PM »
here what I use
http://www.cb-town.com/images/mightyone/gallery/default.htm
similar to the 2x4 one also posted but no pin up front so you can flip the motor over
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline CycleRanger
« Reply #11 on: October 04, 2011, 02:25:16 PM »
Yes, this is what i was talking about.
« Reply #12 on: October 05, 2011, 11:23:38 AM »
In the body shop we called it rottisery  :)
