Author Topic: What is this in my handle bars??  (Read 1767 times)
Offline deebz
« on: October 03, 2011, 09:49:53 PM »
I went to put my new bar end mirrors on, cut the end off my throttle side grip and found this in the end of my bar. Also the end of the plastic piece of my throttle sticks out about 3/4 of an inch past the end of the bar. What is this thing?? It's a 74 cb750, thanks for the help.
Re: What is this in my handle bars??
« Reply #1 on: October 03, 2011, 09:54:14 PM »
It's either a bar end weight to reduce vibration, or someone mounted bar end before, the left the stub after the mirror broke off.
Offline Scott S
« Reply #2 on: October 04, 2011, 04:45:57 AM »
 And you'l have to trim the throttle tube slightly (and the rubber grip), either with a fine toothed hacksaw or a Dremel tool. Just enough to clear the end of the handle bar. Make sure the grip doesn't catch on the mirror and cause the throttle to stick.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: October 04, 2011, 04:59:18 AM »
You may not have to trim the throttle tube.  Is there any room to slide MC and throttle grip in? Are these the stock parts?
Offline Scott S
« Reply #4 on: October 04, 2011, 08:19:30 AM »
 Gordon is right. I should have said you'll have to trim the throttle tube IF you're using the stock locating pin. Otherwise, just slide the control in.
'71 CB500 K0
'81 Yamaha XS650
Offline deebz
« Reply #5 on: October 04, 2011, 11:44:23 AM »
So this is what it is/was.....looks like a weight/vibration reducing dewhickey???? There's one in the other side too.  I think I'm just gonna order some superbike bars and start fresh.
