Author Topic: Bike wont start unless clutch lever is pulled  (Read 3176 times)
Offline Johnny5
    • CB350F build thread
« on: October 05, 2011, 04:47:04 AM »
Strange. This just started happening. My CB750 will only crank over if I pull the clutch in. It wasn’t like this before my last ride last week. If the bike was in neutral, I didnt have to pull the clutch.
Without the clutch pulled, I get nothing. The headlight dims when I hit the start button, but no clicking sound or anything. Only when I pull the clutch lever, then the bike will start up. Is there a wire connection that may have come loose?
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
KingCustomCycles.com
Re: Bike wont start unless clutch lever is pulled
« Reply #1 on: October 05, 2011, 05:04:38 AM »
Some had clutch switches that kept the engine from cranking unless it was in neutral or the clutch pulled in.  Be thankful we don't ride Kawasaki.  They also had a kickstand switch that was prone to failure.
Offline lrutt
« Reply #2 on: October 05, 2011, 06:12:34 AM »
but they are all easily bypassed with short jumpers.
Offline CycleRanger
  • No comment about being an
« Reply #3 on: October 05, 2011, 07:09:16 AM »
Does the neutral light still light up?  If the neutral switch is bad it would cause your symptoms.
You need to check the starter safety circuit. That includes the clutch switch, the neutral switch, diode and associated wiring.
Grab the manual and break out the wiring diagram.  :)
Offline Johnny5
« Reply #4 on: October 05, 2011, 07:42:44 AM »
Yeah, the neutral light works.
1971 CB350
1973 CB350F
