Author Topic: Oil & neutral lights work - nothing else! '71 CB500  (Read 2390 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: October 05, 2011, 05:55:34 PM »
Just got finished wiring up the CB500 I've been rebuilding. I turn the key and all that works is the oil & neutral lights... no headlight, no blinkers, no brake light... nothing. I've never worked on electrics before and don't have a multi-meter at hand. Any suggestions about where to start?
Offline buffaloejon
Re: Oil & neutral lights work - nothing else! '71 CB500
« Reply #1 on: October 05, 2011, 05:58:40 PM »
Get a multimeter. Otherwise you'll be chasing invisible problems.
But without that, check all grounds, and then check all connections. I would say grounds first, as well as where they hook into the ignition circuit?
Just going out on a limb, trying to be helpful!
BTW, did you totally rewire from scratch, or re-use stuff?
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
76 CB750K
http://photobucket.com/buffaloejon
Offline rklystron
  • I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
« Reply #2 on: October 06, 2011, 02:43:33 AM »
+1 on the Multimeter. They are very cheap and easy to work with. It's a necessary tool for the tool box and will make your life happy again.
1970 CB750 K0 (Bought in 73)
1972 XL250 (Bought new in 72)
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
1982 CBX1000 Pro-link
1975 CB750 DRAG BIKE
1977 Custom Built CB750 Sturgis Bike (GL front end).
1977 CB750 F2 (Big Resto)
1977 CB750A (Auction Buy)
1978 CB750 K8 (My San Francisco ride)
1984 VFR750 (Bought New)
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #3 on: October 06, 2011, 08:54:47 AM »
It's the stock harness. The bike only has like 12k on it and was kept inside.
Offline Goldbug
« Reply #4 on: October 06, 2011, 09:07:49 AM »
I say ignition. An EMGO ignition should run no more than $20 on ebay and take no more than a few minutes to install. My '73 CB500 did the same thing, plus other weird stuff.
But a multimeter will tell for sure. They are like <$20 at auto parts stores.
If not then make some simple jumpers out of alligator clamps so you can bipass stuff to figure out where the problem is.
Electrical problems are usually pretty easy to solve unless they are intermittent, then it's more of a pain.
« Last Edit: October 06, 2011, 09:11:39 AM by jwarriner »
Offline rklystron
« Reply #5 on: October 06, 2011, 09:23:50 AM »
Unless you have some way to determine where there is and where there is not voltage (12v) you will have little change of solving you problem of unless course it is obvious. A connector that has become disconnected ect. Have you looked at all your connections? The black wire on a CB750 supplies 12V through out the entire system not sure if that is the same for your bike. Do you have a wiring schematic? If so look at the connections to be sure you have everything connected properly. Without a meter or a test light I dont think anyone can help you.
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
Offline Goldbug
« Reply #6 on: October 06, 2011, 10:10:54 AM »
If you have a basic understanding of the wiring diagram for the CB500 (which I do) you can make educated guesses. I'm going with ignition switch for a couple reasons. We KNOW power is getting to the switch because the neutral/oil light work (so black wire is fine). The only thing the headlight and tail light have in common is everything up to the ignition switch, after that they diverge within the switch. The headlight could have a problem in the hand switch but the tail light would still work in that case. So you gotta think the problem is not before the switch. For everything not work after the switch you'd have to have multiple points of failure. But if you think you only have one problem then that problem is the switch.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #7 on: October 06, 2011, 12:17:59 PM »
Thanks JW - that's all I was looking for.. a place to start. Will get a meter when I get back from Barber and have a go.
Offline Spiider
  • '73 CB750k
« Reply #8 on: October 06, 2011, 04:06:14 PM »
12v test light is a valuable additional diagnostic tool as well....and you can get one at the same place you get the multimeter for very little money.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #9 on: October 10, 2011, 02:36:52 PM »
So do you mean the actual switch that the key goes into?
Offline Goldbug
« Reply #10 on: October 10, 2011, 03:24:26 PM »
Yes.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #11 on: October 20, 2011, 07:47:08 AM »
Ignition switch replaced - still nothing but oil & neutral. So what's next? Check ALL of the connections? Or does the fact that it's not the switch point to something more specific?
Offline TicoCafe
« Reply #12 on: October 20, 2011, 07:56:55 AM »
I would now check and CLEAN ALL electrical connections. A small Wire brush and electronic cleaning spray solvent should speed the cleaning process.
Pura Vida!
Offline Lorbaez
  • CB Power
« Reply #13 on: October 21, 2011, 01:55:47 PM »
did you solve the problem?
Considering that positive is common, and just this two lamps uses "independent" ground, it seems that green wires are not properly connected to the frame.
With a multimeter you have to check continuity of green wires and ground (frame).
CB500K Re Styling
[http://forums.sohc4.net/index.php?topic=101860.0]
72500john
« Reply #14 on: October 21, 2011, 04:54:29 PM »
try this link it may help.
http://oldmanhonda.com/MC/wiring.html
Offline Silverback1
« Reply #15 on: October 21, 2011, 05:05:17 PM »
A simple solution is a test light it requires a connection to earth then check each wire with the probe (ignition must be on), the light will light up if power present.
It is quick way of finding if power present, but a Multi Meter is the best method to detect power and volts.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #16 on: October 24, 2011, 10:14:28 AM »
SUCCESS!! Was standing there staring at it, about to take the dive and start checking all of the connections when I noticed that two wires on the rear fender were unplugged (black and green/brown I think). There had been a rag sitting there and that's why I hadn't seen it before. Plugged 'em in and BAM! Checked the old switch and it was fine - which is cool since the EMGO I got as a replacement evidently sucks. SO GLAD that it was just this and not anything more serious. Thanks all!!
