Author Topic: Resurrection of a cb750 K6 (update 9/28/12)  (Read 51431 times)
Offline hoodellyhoo
  • CB350F
Re: Resurrection of a cb750 K6 (update 12/16/11)
« Reply #50 on: December 16, 2011, 04:15:06 PM »
It's about time for a proper update. I've been pretty busy with school lately but now the that the semester is winding down I had the afternoon to work on the 750.
A few weeks ago I had some time and got the carbs finished up. I cleaned up all the fuel line clips and "T"s on the wire wheel. I had some leftover new fuel line from other rebuilds so that went on. I'm glad to be done with them because these were deffinitely the worst carbs I've done so far. They didn't look that bad but the crud that was there was VERY hard to get out. Too bad I can't justify spending $60 on new rubber dust boots. I don't like the way the look without them but that's too much money for four little bits of rubber.
Today's main mission was to try and remove the exhaust. That way I could clean it really well and then finally get off the left side crash bar. Basically, this is a job I hope I never have to do again. Obviously the headpipes were really clamped/rusted on to the spigots. After much smacking, twisting, wedging, etc, I was able to get just the slightest amount of twisting motion at the headpipes. I realized I needed a second pair of hands to do some pulling while someone else twisted. My dad came to the rescue and after an hour of more smacking, twisting, wedging, PB blaster, etc., we got both exhausts off!!! Woot!
The other thing I wanted to get done was remove all sorts of things so I could work on them in the house.
The brakes came off first. I was smart this time and used the master cylinder to push the caliper piston out before I took it off the handlebars. I didn't inspect it too closely but the piston seemed in good shape so hopefully that won't need replacing. The caliper arm also came off so I could grease it.
I finally drained the gallon of really old gas out of the gas tank. I'm going to see what I can do to it with some polish. There's no plans for new paint so I want to make the original paint look as good as possible.
I stripped the bike pretty good. Everything will get cleaned and polished before going back on. This bike is really dirty and I want to clean and detail it as best I can before I start riding it.
As an added bonus I found out our garage stays pretty warm. The garage door is insulated and that held the heat in fairly well. LOTS better than the open garage I was using to work on my last K6.
I've been debating a lot about my carb insulators and airbox rubbers. Some of the insulators are cracking and I don't know if I feel like experimenting more with the airbox boots to see if I can get them to expand back to their original size so they fit tight in the airbox. Since I plan on keeping this bike a long time and putting on plenty of miles I think I'm just going to bite the bullet and buy all new rubber even though my wallet will hurt. I think it just makes the most sense.
Offline K5owner
« Reply #51 on: December 16, 2011, 05:14:30 PM »
Your K6 project brings back memories of when I did my K5. I like what your doing... nice work!. Here's a link to my project. http://forums.sohc4.net/index.php?topic=99502.0   I have more photos, so if you'd like to see something different; let me know. Sold most of the leftover parts, but still have a few. Let me know if need something.
Look forward to seeing your progress.
-Ray
-Ray
Remembering the past...   Livn' the dream
1975 Honda CB750 K5, Restored Aug/2011
1971 Honda CB175 K5, next project
1977 Honda CT70, swap meet scooter
2004 Honda NRX1800 (Rune), Cruiser
1977 Honda GL1000, daily driver
Offline dhall57
« Reply #52 on: December 17, 2011, 03:43:40 AM »
Hoo, Did you bite the bullet and get some new 341's on the way ;D I hope to get some for my K6 in 2012. Been running the Mac 4 to 1 since getting the bike in 2009.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Johnie
« Reply #53 on: December 17, 2011, 06:14:00 AM »
Glad to see you got those pipes off. They can be a bugger. You are making some good progress. Any plans for the forks or shocks?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline hoodellyhoo
  • CB350F
« Reply #54 on: December 17, 2011, 08:01:23 AM »
Yeah right...
It doesn't help that decently priced used sets keep coming up for sale.
Offline hoodellyhoo
  • CB350F
« Reply #55 on: December 17, 2011, 08:05:48 AM »
The whole front end will get a rebuild like I didn on the 350 except I plan on doing tapered stearing bearings. Shocks I would like take apart and detail like you do.
I was also thinking about the milage on bike and that I better put in new wheel bearings. You might need to help me with that.
Offline Johnie
« Reply #56 on: December 17, 2011, 11:58:53 AM »
No problem on the wheel bearings. I get them at a local supplier located next to the Leon Frozen Custard stand. With such low mileage and no oxidation on my K3 this is the first bike I do not plan on changing the bearings on. Cost is small too.
« Last Edit: December 17, 2011, 12:00:25 PM by Johnie »
Oshkosh, WI  USA
Offline hoodellyhoo
  • CB350F
Re: Resurrection of a cb750 K6 (update 12/18/11)
« Reply #57 on: December 18, 2011, 03:21:27 PM »
Didn't have much homework so I got some bike hours in today. I fought yet another fight with the dreaded master cylinder circlip. This one wasn't as bad as some and I figured out a better way to hold down the piston so I could fit in the circlip pliers. You put the lever bolt in and pivot a screwdriver on it with the handle held in place against your body. This frees up one hand to hold the master while your other hand is completely free to work the pliers.
Even after the circlip was out the insides didn't budge so I had to hammer them out from the other side.
I cleaned up a few other parts, including the petcock, and once they dry later I'll reassemble them. The paint is flaking pretty bad on the caliper so I guess I'll paint that (I hate painting).
The rest of the day was spent working on the wire wheel. My exhaust clamps were all really rusty so they needed the full treatment. The after picture makes them look worse than they are. They certainly aren't perfect but no longer an eyesore.
Offline lucky
« Reply #58 on: December 19, 2011, 02:45:30 PM »
That place you found that bike looks like it was one day from burning down due to poor housekeeping!!! What a mess.
Offline Johnie
« Reply #59 on: December 19, 2011, 07:36:26 PM »
Sometimes those places hide the best bikes too.
Oshkosh, WI  USA
Offline hoodellyhoo
  • CB350F
Re: Resurrection of a cb750 K6 (update 12/30/11)
« Reply #60 on: December 30, 2011, 03:39:00 PM »
Winter break at school means more time for bikes!
First step was reassembling the petcock. I had trouble remembering where everything went. It didn't help that there were some new parts that weren't present when I cleaned the petcock on my last K6. I think I got it back together right  ??? I looked to see if some of the seals were available new but all I could find was the screen or a complete petcock. Since it wasn't leaking before I'll let it be with the old seals. If it aint broke...
Spent a while today cleaning rust and corrosion from bits of brake hardware. The soft wire wheel I got at sears really does a nice job. As you can see I took the nasty yellow covering off the brake lever and gave it a slight polish. The clutch lever needs the same treatment.
As I said before I was planning on rebuilding my master cylinder by just replacing the rubber bits from a kit that I had only used a very short while in my 350. Turns out I'm just going to have to buy a new rebuild kit anyway. I put the master cylinder piston on the wire wheel to clean it up and I found this underneath  :o:
The pitting on the right doesn't matter but there is too much on the face of the lip that seats the seal that goes on it. Since my "spare" piston is also no good (has some slag from improper machining), it's time for a new kit.
I wanted to finish out the day by cleaning out the rust around the bore of the master cylinder where the washer and circlip go. Turns out that my wire brush for my dremel that I use to do this was no good so I had to run to the store for a new one. Times up for today but I might get some time in tomorrow afternoon or sunday.
Offline Johnie
« Reply #61 on: December 30, 2011, 04:34:09 PM »
Looking good there T...
Oshkosh, WI  USA
Offline hoodellyhoo
  • CB350F
Re: Resurrection of a cb750 K6 (update 1/4/12)
« Reply #62 on: January 04, 2012, 07:01:19 PM »
Over the past few days the mailmen have brought all sorts of wonderful new parts. Today I got most of my rubber parts including my new airbox boots and airbox gasket. My old boots had shrunk too much and have gone hard again (but they still smell like the wintergreen oil). I figured it wasn't worth the hassle to keep trying to revive the old rubber because in the end it's still just old rubber. Now that I've had the chance to compare the old and new boots I'm really glad I bought the new stuff. Check out the size difference between the two!! The new boots fit so tight there's no way they will leak any air.
Even though the old airbox boots have hardened up, my carb insulators are still soft. Unfortunately there were some cracks on them so I bought a new set just for the peace of mind. Strangely, my new set is stiffer than my old set.
And since it was still the christmas season I went ahead and treated myself to new carb dust boots 8)
Most days when I get home from work I'm so tired that I don't feel like doing much of anything but today after playing with my new parts I grabbed some chrome polish and cleaned up a few parts. There's some deep pits on the clutch cover and kicker but nothing I'm too worried about.
Offline MikeKato
  • Milwaukee WI
    • TCB true life stories
« Reply #63 on: January 05, 2012, 01:31:52 AM »
Wow,those boots look like they were swimming with George Costanza! Looks like you've come a long way in fixing and cleaning your bike,looks nice. The calendar says we're only a couple months away from our spring thaw but winter hasn't even arrived yet,hope it's not a replay of last year when we struggled to hit 50 degrees until May.  Maybe sometime you could tell us more about the PO's bike collection? How many did you sell and what were they?
GL!
Mike
Offline Pecantree
« Reply #64 on: January 05, 2012, 11:56:54 AM »
Just read your build threads.
You do good work!
Also have the same color K6, which I think is just gorgeous with the patina of age.
Came with the same gawdawful seat but luckily the PO kept the original. So a quick swap was all I needed!
Subscribed, Will be following this rebuild.
Steve
« Reply #65 on: January 06, 2012, 05:42:56 AM »
Lookin' good,think you will be making old Johnie jealous over there in Wi. One little nit pik thing I noticed is I would swap your inner float bowls on your carbs before you mount them so the drain screws are in the right direction  ;)  Now get back to that polishing wheel  :D    Eric
Offline hoodellyhoo
  • CB350F
« Reply #66 on: January 06, 2012, 07:24:32 AM »
Ha! good catch there. I did the same thing on the 350 last spring except you have to remove the carbs to pull the float bowls. Needless to say I put that job off for a long time.
Offline hoodellyhoo
  • CB350F
« Reply #67 on: January 06, 2012, 02:26:35 PM »
Today was spent buying books for school ($$ ouch!!) and then getting a lot of parts ready to sell to fund this project. Since I wanted to get something done for the bike today I disassembled, cleaned, and polished the front blinkers.
Before and after:
Oh, and I switched those two float bowls around  ;D
Offline hoodellyhoo
  • CB350F
Re: Resurrection of a cb750 K6 (update 1/9/12)
« Reply #68 on: January 09, 2012, 07:56:27 PM »
Been working on the bike the past couple nights, mostly cleaning stuff up. As filthy as this bike is, there's plenty to clean. My hope is to get it spotless before spring. In my quest for a clean bike I began cleaning up the exhaust. Remember these guys?
They looked worse in person than in the pic. I decided to start on the left side first because it would be harder. This has probably been the messiest motorcycle job I've done yet.
The p.o. must have never cleaned the backside of the pipes because there was a lot of chain grime and it was baked on solid. I had to resort to using a brass grill brush to get the worst of it off, which unfortunately left scratches in the chrome. It's not too bad and polishing it helped a little but you can see the duller areas where I had to really go at it with the brush. At least I can now pick up the exhaust without needing gloves. Hopefully the other side is much easier.
Next on the list was cleaning up the gauges. The chrome backings had a thick layer of corrosion, almost as if they were just on the verge of full-out rusting. After cleaning the dirt off of everything, some steel wool and polish did the trick on the chrome.
Before and after
And here they are all put back together
Offline dhall57
« Reply #69 on: January 10, 2012, 03:10:01 AM »
Good job on the gauges Hoo. I like the green face gauges on the K6's. Your going to have a super nice bike when done ;D I might have to take a road trip on mine and come up and see it ;) Why didn't you invite Johnie over to help you clean up those nasty pipes ::)
By the way, it's great to see a young guy like you so interested in these old Honda's.
« Last Edit: January 10, 2012, 03:21:45 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline hoodellyhoo
  • CB350F
« Reply #70 on: January 10, 2012, 03:23:50 AM »
I always liked the green gauges too. Although, I must confess that sometimes I think about painting the bike planet blue someday like a K5. Too bad the K5's come with blue gauges. And yes, I think this bike will turn out quite well too. I'm going to have to lay my hand on just about every nut and bolt to clean it the way I want to but I think it will be worth it. I usually don't have the patience to do that much work to something but I'm driven by the though of the finished product. That, and I have to give john a run for his money ;)
I started working on the pipes the day john had his son's wedding so I figured he was busy, but maybe I'll give him a call when I start the right side pipes tonight ;D
Offline Johnie
« Reply #71 on: January 10, 2012, 05:29:10 PM »
Hoo....I love cleaning pipes and will be right over...oh wait...I am in MI for the week for work. Maybe I can help you on the next one.  ;D Looking good there. I can recall what that K6 looked like when we rolled it into the trailer. You are making good progress and it is looking very good.
Oshkosh, WI  USA
« Reply #72 on: January 10, 2012, 07:12:42 PM »
Hey Trevor great work! For the nasty grime on the pipes try a can of cheap brake cleaner - I used this on my oil crusted HM300s and it slid right off. No scratches and then use chrome polish afterwards. Painless!!
Good luck!
Andy
Offline hoodellyhoo
  • CB350F
« Reply #73 on: January 10, 2012, 07:25:58 PM »
Don't worry johnie, I can wait till you're home next week. I've got plenty of other things I can do ;D
Good luck!
Andy
Thanks for the tip. I was thinking I should have tried that....after I found the scratches. It's really not a huge deal though. The pipes still look perfectly presentable and waaaaay better then before.
Offline hoodellyhoo
  • CB350F
« Reply #74 on: January 10, 2012, 07:32:02 PM »
Didn't do anything much to the bike tonight. I wanted to get it up on the lift while it's still warm in the garage so that it's easier to take the front end off. Had to go to the store to get some rachet straps to hold it down and then stop by my parents to get my blocks of wood to put underneath the frame rails. By the time I got the bike lifted and secured I was out of time. At least she will be warm now undereath the new cover that santa brought. Should be able to get more done in the next few days. School starts up again on monday which will take away most of my project time :(
