Author Topic: '76 CB750K Runs descent but smokes out #4 exhaust, troubleshooting  (Read 981 times)
Offline stickman
  • A vintage 750 is a terrible thing to waste....
Hey folks,  I have been off the forum for several months and have always received great advice and help here.
Just picked up a 76 750K running but smoking from the #4 exhaust.  It is a light blue oil smoke I think.  No unusual noise that would suggest broken or damages parts.  PO says was parked for approx. 2 yrs. before he tinkered and got it running recently.  Bike has not been put in service since getting it started.  Now I need to troubleshoot to determine what my issue is.  My skill level is modest.  So I have a few questions and am asking for any general info or suggestions from the group.
1.  Any wisdom in just putting the bike in service for a while in hopes that its a stuck ring and frees up?
2.  If I do a compression check, what should I look for?
3.  Other ideas?
Thanks in advance for any input...........Stickman
Ed Jones, Lenoir, NC
1971 CB750, 1994 Kaw police bike KZ1000
Re: '76 CB750K Runs descent but smokes out #4 exhaust, troubleshooting
« Reply #1 on: October 09, 2011, 06:24:18 AM »
You will be OK to run it in for awhile and see if it is a ring that may loosen up and improve. Little seafoam in that hole for a soak won't hurt and maybe a little shot in the gas tank. I have ran a little in the oil tank also for a bit before an oil change.
Offline trueblue
« Reply #2 on: October 09, 2011, 06:32:13 AM »
Does the smoke clear when you rev it or get worse, bring the revs up to about 3 to 4k and hold for about 5-10 seconds,  if it clears then it is likely the valve guide seals, to test the valve seals give it a few sharp raps on the throttle, only to about 4k ish, if it gets significantly worse it is probably in your top end. ;)
1979 CB650Z
Offline stickman
« Reply #3 on: October 25, 2011, 08:20:51 AM »
Thanks guys for the thoughts.  Nothing much to report yet, just wanted to acknowledge the feedback.  I poured about and ounce of seafoam on top of the pistion on #4, let it sit overnite and yesterday fired her up.  Hitting on all 4 cylinders and temp check on the header pipes showed only minor lower temp on #4.  The light blue smoke is still there but seems slightly less volume.  The amount of smoke increases when the throttle is pushed upward but nothing significant from idle.  I suspect that it may be burning off some excess oil/gas stored up inside the #4 exhaust( it has drag pipes so each cylinder is easy to keep tabs on.  My plan now is to put fresh fluids in and take her out for a run and see if it improves any.
I will report back.  Thanks again for the input.  Stickman
Offline trueblue
« Reply #4 on: October 25, 2011, 01:16:08 PM »
One other thing I should add, if it gets significantly worse when it is under load it is likely your rings not sealling properly, which could mean they are worn or just stuck.
1979 CB650Z
