Author Topic: 74 cb750 running issues  (Read 3265 times)
Offline tanman855
« on: October 09, 2011, 08:57:48 pm »
This bike has been sitting for about 10 years, I cleaned the carbs, replaced fuel lines, changed oil, changed plugs. It runs awsome at idle, fires on all four and revs good. But When I take it out, I only get full power some of the time. If im riding wide open it bogs down so I opened the choke then shut it and it takes off then. So does that mean it is running lean? I think this might be the problem because it is running straight out of the headers and no air filter whatsoever. I recently purchased the pod filters and a set a of jets that come with them.It's in the mail and I'm hoping this fixes the problem of it bogging down around mid-high range.
1974 cb750 (cafe in progress)
Offline bluesmoke69
Re: 74 cb750 running issues
« Reply #1 on: October 09, 2011, 09:13:34 pm »
Need to inspect the plug color. Are you on reserve instead of on, and how full is your gas tank. One more thing check routing of fuel line.
Offline tanman855
« Reply #2 on: October 09, 2011, 09:17:00 pm »
The plugs are dark but lighter on the end of the ground electrode. And it is on reserve, there is fuel in the lines (they are clear).
Offline bluesmoke69
« Reply #3 on: October 09, 2011, 09:33:18 pm »
I don't recall the place that I read it, but it said something about low fuel levels making the 750 not run right. Especially on reserve. hope this helps. Search the forums.
Offline tanman855
« Reply #4 on: October 09, 2011, 09:46:08 pm »
Ill top it off tomorrow and see if it helps, thanks.
Offline Zim
« Reply #5 on: October 09, 2011, 10:00:45 pm »
Having no air filter and an open header is definitely not helping your cause.  Make sure your carbs are synced as well.
« Reply #6 on: October 09, 2011, 10:14:09 pm »
+1, i explained this in reply to your other post... ;)
Not enough back pressure without the rest of the pipes and no stacks, it will never run right like that....Jetting would also be all over the place.
Do as Scottly suggested and put all the stock parts back on, tune it then and see how you go, then your questions will be a little easier to answer.....And, welcome to the forum mate..... ;)
Offline NewOldSchool
  • Apprentice
« Reply #7 on: October 09, 2011, 11:32:06 pm »
Pod filters are one of the worse things you can do to your motor. It will be difficult to get it to run great with pods, stick with the stock air box and go from there.
Not putting miles on your bike is like not having sex with your Girl Friend so she'll be more desirable to her next Boy Friend.
Offline tanman855
« Reply #8 on: October 10, 2011, 03:36:30 pm »
K put the pipes back on and the air box, it runs better and revs up to 6 very well. But I still have the same problem, as soon as I get under power it bogs down around 5k rpm and is taking its time getting to 5k. And when im bogging down at 5k I flip the choke on then off and it takes off like crazy.
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: October 10, 2011, 04:07:16 pm »
This may be a dumb question, but is the air filter in the air box?
« Reply #10 on: October 10, 2011, 04:18:25 pm »
Pulling the choke on richen's up the fuel air ratio. I would be looking at jets , if it is idling well then main jets could be either blocked or to small. If the air filter isn't in the airbox, you could experience the lean condition you describe as well.... Are you running fuel filters.?
Offline tanman855
« Reply #11 on: October 10, 2011, 04:35:04 pm »
it aslo leaks a lot of gas out of the overflow tubes
« Reply #12 on: October 10, 2011, 04:37:54 pm »
Sounds like your carbs need a good going over....
Offline Johnny5
    • CB350F build thread
« Reply #13 on: October 10, 2011, 04:45:25 pm »
Agreed. Double check your floats for sure.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline tanman855
« Reply #14 on: October 10, 2011, 05:49:21 pm »
I discoverd it is having a fuel drawing issue, but im not sure where I should be running the fuel line to the far side.
Offline tanman855
« Reply #15 on: October 10, 2011, 06:13:59 pm »
YAHOO! re-routed the fuel lines and the bogging down is almost gone, still a little hesitant but a lot better! I think I'm going to go up a jet size only problem is I'm not sure what size I have. is there supposed to be a number printed on them?
« Last Edit: October 10, 2011, 06:16:12 pm by tanman855 »
Offline alfego
« Reply #16 on: October 10, 2011, 07:42:54 pm »
How many turns out do you have your air screws set?  Try bottoming them and turning them a 1/2 turn out.  That will richen it, and it should run much better up to 5K rpm.
Alfego
Offline tanman855
« Reply #17 on: October 11, 2011, 02:56:47 pm »
Those screws were the ticket!
« Reply #18 on: October 11, 2011, 07:43:30 pm »
Nice..... ;D
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #19 on: October 12, 2011, 08:35:03 am »
I had to adjust my screws a bit yesterday also. Was running kind of lean I believe. With the colder weather, I'm thinking it was leaning out a bit with the dense air.
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
