Author Topic: Cylinder head dome nuts  (Read 1613 times)
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« on: May 14, 2006, 01:33:46 PM »
400f
Fitted cylinder head last night, checked it again today before continuing with rebuild and one of the chrome dome nuts striipped it's threads.
Torqued down to 14.5 ft/lbs
Is this a known problem? should I now strip down again and buy new replacement nuts?
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Cylinder head dome nuts
« Reply #1 on: May 15, 2006, 06:04:21 AM »
14.5 sounds high - is that the spec in your manual?
« Reply #2 on: May 15, 2006, 08:21:19 AM »
Just replace the suspect nut(s) and check the stud threads. As i remember it there are copper sealing washers under some of the nuts but cant remember which ones, or indeed be sure i am right
supersport_CB400F
« Reply #3 on: May 15, 2006, 03:20:20 PM »
I'd back them off in the proper order get new ones and do it again ...if the studs are not good let me know I have some spare ones knocking around you can have if I have the correct size.
Dave
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #4 on: May 16, 2006, 09:56:28 AM »
thanks Dave, the stud looked fine, just the threads pulled straight out on one nut, I put another standard nut on straight away to keep the tension even on the whole of the head, my worry is now that other nuts may be very weak too. I have ordered a complete new set of 8.
Do you think it will be ok to back them all off again and then retighten with new nuts and not replace head gasket etc?
Since it was not a total rebuild, just a reassembly of the top end as I received it, I wanted to get it up and running to find out what it sounded like, run it until Winter then remedy anything found. Reluctant to spend too much at this stage.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
supersport_CB400F
« Reply #5 on: May 16, 2006, 11:14:26 AM »
Malc if you never run the engine and the metal expanded I'd use the gasket again, some guy I knew used his old gasket and never had a problem but it was the original Honda graphite type one lucky sod!
Dave
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #6 on: May 17, 2006, 06:45:07 AM »
ok Dave, not sure what you meant "and the metal expanded" but just tightened head down & went no further, the cylinder base gasket was smeared with grease to help seal and seat. The head gasket used was in a new 'Genuine Honda' kit and came with bike, I seem to remember it was very pliable and black like graphite.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
supersport_CB400F
« Reply #7 on: May 17, 2006, 10:37:49 AM »
I meant the engine had not run and got hot Malc …..You should have no probs torque it then leave it for a while then do it again and it’s happy days.
Dave
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #8 on: May 18, 2006, 03:00:15 PM »
ok got my new cyl head nuts today, they are very different to the orignals I have, they are plain steel the originals were chrome plated, also have a large washer type base. Were my originals the correct one's? the metal certainly seemed quite brittle which maybe why they stripped threads.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
supersport_CB400F
« Reply #9 on: May 18, 2006, 03:17:33 PM »
Your new nuts look the same as my original nuts......god if ghouliie gets on this one I'm going to fall off my chair .......those new ones are the nuts Malc sorry but I'm smiling big time I'll flash up a photo in the morning sorry mate use them with the copper washers  ;D
« Last Edit: May 18, 2006, 10:32:24 PM by _biffta_ »
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #10 on: May 19, 2006, 10:08:43 AM »
phew!!! my nuts look like everyone else's now  ;D
I tried to be carefull how I worded my message early on to stop any double entendre.
Thanks Dave
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
supersport_CB400F
« Reply #11 on: May 19, 2006, 10:42:38 AM »
Thanks Dave
Malc I prefer the word fastener, at least I can keep a straight face while I’m typing ….sorry I’m just a scoucer with a sick sense of humour  ;D  ;D
