In an earlier post I mentioned that a previous owner had cut off the rear upper shock mounts on my 1976 CB750K to lower the shocks using a home made lowering assembly (read: butchered).
I was going to have some new shock posts fabricated and welded onto my existing frame to straigten things out but recently ran across two rolling chassis from 1971 with many useable parts, including the frames, for only $200.00.
Are the frames from 1971 the same as from 1976? If so, it might be just as cost effective to simply swap frames. I heard that Honda improved and strengthened the swingarms in 1976, and the part numbers are different, but I thought you folks with more knowledge than me might know definitively if a straight swap is possible.
Frame part numbers:
1976 - 50100-341-670ZA
1971 - 50010-341-010B - same number to and including 1975
